| Strada Abarth wheel sizes? Can anyone tell me the offset of the Strada wheels? Thanks.
| Re: Strada Abarth wheel sizes? Tires are 185/60/HR14 and alloys are 5.5x14
| | #3 | ||
| NobodyBlamesTheHappyGuy:D | Re: Strada Abarth wheel sizes? It may differ from models. I think our Abarth's wheels are 60 mm offset. Had to use 20 mm (should be 25 mm) Momo spacers to make them fit an Uno 1.1 ie . The Abarths on the pictures are 130 TC.Morten.
__________________ jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint. member of the 5-door massive attack. | ||
| | #4 | ||
| The Thrill of Driving.... | Re: Strada Abarth wheel sizes? I have a set of 5 Strada Abarth wheels from a 130TC in my garage that are 5.5J 14" ET60 its stamped on the rim Aaron.
__________________ ![]() 1992 Lancia integrale EVO1; 1995 Toyota Celica GT4 ST205; 2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's) | ||
| | #5 | ||
| Re: Strada Abarth wheel sizes? Ahhh, all becomes clear. 60mm offset, no wonder I couldn't fit them even with spacers to my exxy. Offset is only 25mm on the exxy so that would have to be one hell of a spacer. Seems like I've got a set of 5 Strada Abarth wheels for sale with new tyres. Bloody ebay, seller said they were 35mm offset. Also seems like I'm in the market for another set of cheap 14" wheels with an eighties style and a more managable offset, ideally 25mm, any suggestions. Thanks for the info so far.
__________________ "Fish" X1/9 Turbo, "Ron" X1/9 1300, "Scud" 166 3.0L V6, and now Marea 2.4JTD Weekend as yet unnamed. Not forgetting "Barchetta" but this one really floats. Probably the only Fiat TD powered boat. It seemed like a good idea at the time! | |||
| | #6 | |||
Check the rim tho it should have on one side if they are like mine 5.5J 14H ET60 and across from it Cormadora, tho if they have been refurbished its harder to see this if paint was put on thick. i believe earlier Strada's did have a diff off-set, maybe 40 but I've never had one so can't know for sure. You can measure the offset use this if unsure of how to do it http://www.rsracing.com/tech-wheel.html as you will find that if the wheel is a diff width the offset differs, so if this wheel is wider than your original then the offset will invarably be higher as you will be putting the extra width to the isdide of the wheel arch to keep the wheels outer face in same position as original wheel if you follow. HTH Aaron.
__________________ ![]() 1992 Lancia integrale EVO1; 1995 Toyota Celica GT4 ST205; 2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's) Last edited by J333EVO : 09-07-2006 at 21:53. | |||
| How many Stilos | activematt | Stilo | 755 | 12-11-2007 14:17 |
