FIAT Auto Specialist Team
Thread Tools
Old 21-07-2017   #1
New Zealand
Smile 130tc Front / Rear Windscreen
Hi guys - quick question ! - can anyone tell me if the 130tc front/rear windscreens are the 'pop-in' type that you can install yourself with the 'string in the groove' trick ie with no sealant. Any advice from DIYérs appreciated ! Cheers Hamish
hkofoed is offline Reply With Quote Quote
Old 22-07-2017   #2
s130 has donated!
Re: 130tc Front / Rear Windscreen
Front and Rear screens/glass are "traditional" screen in rubber surround assemblies with no glue/bonding required.
This means that yes you use the "waxed cord" method for installing the screens.
Secret tip
With the bonnet open then on either side underneath scuttle there is a (long) bolt that secures and allows the dashboard to be lowered away from the bottom of the windscreen area. Lower the car steering wheel and then evenly undo these two bolts. If you do not do this then you will have great difficulty with fitting the bottom edge.
They are quite long bolts but suggest do not fully take them out.
s130 is offline Reply With Quote Quote
Old 23-07-2017   #3
New Zealand
Hi s130 - thats great information and a handy tip ! Cheers. Will share more pics as the beast is re-assembled !
Thread Tools
(G) front windscreen puntoboii Grande Punto 14 03-03-2013 20:03
Front windscreen kosak Bodyshop 0 14-02-2012 23:09
(T) Front/rear windscreen washer does not work fiatritmo Stilo 4 09-05-2011 15:04
Front windscreen Anonymous FIAT Boo Archives 14 23-09-2003 00:33
