The FIAT Forum
Go Back   The FIAT Forum > General > Put it to the Vote...
View Poll Results: Water injection - yes or no?
I wanna have it! 1 12.50%
might give it a try... 2 25.00%
Don't need it, don't want it. 5 62.50%
Voters: 8. You may not vote on this poll
Old 19-03-2008   #1
Trader Rating: (0)
imagine you would have a second injection system which would inject WATER instead of fuel.
How would you feel about it?
Zardo is offline
Old 19-03-2008   #2
Wide arch Hormann Turbo
richcinq's Avatar
Trader Rating: (0)
richcinq has donated! United Kingdom
Re: Water injection - yes or no?
Hi
Have an Aquamist water injection sytem on my 1242cc MPi Turbo Cinq. Lets you run higher boost without detonation.
Rich.
richcinq is offline
Old 19-03-2008   #3
Trader Rating: (0)
Originally Posted by richcinq View Post
Hi
Rich.
sounds good. How far will you get with a 10 l water tank?
Zardo is offline
Old 19-03-2008   #4
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
methanol / water, not just water
arc is offline
Old 19-03-2008   #5
richcinq's Avatar
Trader Rating: (0)
I have a water injection kit but I use a 50/50 water+methanol mix. Not sure how far I would get on 10L as it depends how you drive it as it only injects at high boost.
Rich.
richcinq is offline
Old 20-03-2008   #6
an-drewm's Avatar
Trader Rating: (0)
I ran 50/50 water methanol on my 924 Turbo Carrera GT spec. Ran much higher boost. I ran it off the washer bottle which was about 7.5l but was not enough for a long run using the washers/wipers.
an-drewm is offline
Old 22-03-2008   #7
Burninator of threads!
faster4_tec's Avatar
Trader Rating: (0)
faster4_tec has donated! Mongolia
so you can use it for induction cooling AND washing the buggs off the screen.
awesome!!!
TBH water/methanol injection is often substituted for when an engine isn't properly mapp'd, or your trying to get more out of it than what is really safe.
Volvo for Life
faster4_tec is offline
vB code is On
Cylinder Head Gasket remove and refit levemir Cinquecento / Seicento Guides 4 29-07-2008 18:41
water leak cholmondely warner Cinq/Sei > Technical 8 28-02-2008 17:02
99 punto radiator water boiling mackfa Punto 2 13-02-2008 13:59
Water level decreases rapidly Spambam Tipo 8 22-07-2004 00:04
Punto Turbo oily Water Problem didgey101 Punto > Technical 6 09-04-2003 19:28
