| Punto Temp Gauge.. Linked To Fuel? Hey guys, My temp gauge, basically doesnt work. Think the sensors gone or something so gonna get it checked soon. I have noticed reasonably high fuel consumption though since it stopped working.. Is the sensor linked to the fuel consumption via the ecu?
| blessed are the apostates | Re: Punto Temp Gauge.. Linked To Fuel? the coolant temp sensor is probably faulty or there is a wiring fault in its circuit. this will stop the gauge working, and it will also affect fuel economy and performance since the ecu uses the signal from the coolant temp sensor to adjust the fuel injection. when a sensor fails a default value is used instead to keep the car running, but this wastes fuel. the coolant temp sensor is cheap and easy to replace. | ||
| | #3 | ||
| Re: Punto Temp Gauge.. Linked To Fuel? thanking you muchly buddy, i'll look into it =)
| | #5 | |||
| this is where i stand | Re: Punto Temp Gauge.. Linked To Fuel? depends what age punto. the mk1 has seperate sensors for the gauge and ECU.
the sender for the gauge is on the back of the head, timing end of the engine and costs around a fiver the sender for the ECU sticks out the right hand side of the inlet manifold, and is around 30quid. they aint linked.
__________________ Last edited by arc; 14-03-2007 at 02:29. | |||
| | #6 | ||
| Re: Punto Temp Gauge.. Linked To Fuel? wellll im jus gna get them both replaced. thinkin of sellin the car soon anyways so wanna get it in sellable state
| | FiatStiloJTD | Punto | 543 | 06-06-2008 17:15 |
