| Fault code/diagnostics?? Hi, returned from having car diagnostics done, and need to know if anyone knows of a site or information re the fault code. The sepcialist is having to wait to call to find out awhat a specific code is, howerver was wondering if the wealth of knowledge her might have a clue for me to look them up. Ta
__________________ Keep It /F/I/A/T/ | |||
| Forum Moderator | Re: Fault code/diagnostics?? what is the fault code?
| | #3 | ||
| Re: Fault code/diagnostics?? it is U1601 cheers
| | #4 | ||
| Forum Moderator | Re: Fault code/diagnostics?? Network (CAN) error,most U codes are 'pending codes' & can often be ignored...is it a mk2 punto you have? This code is often flagged when key not read correctly,delete it & see if it returns.
| | #5 | |||||
| I Am Legend | Re: Fault code/diagnostics??
| | #6 | ||
| Forum Moderator | Re: Fault code/diagnostics?? I'd just ignore it aslong as car is fine. Another code is U1600 that you see regulary but it doesn't really affect car its just aerial never read key which can be simply caused by having loads keys on key rings...i'd only investigate further if problem occuring with that circuit,faulty areial,ecu,code box etc..
| | #7 | ||
| I Am Legend | Re: Fault code/diagnostics?? Ah i see thanks for that ..
| | #8 | ||
| Re: Fault code/diagnostics?? Ah thats gret thanks for that, it's going into be serviced tomorow and should hopefully be ok after that! however afm also appeared to be sending up an error aswell which is pretty annoying. however i have recently bought a warranty for it, would the afm be classed as a failure due to wear and tear or just a sudden failure do you think? cheers oh btw its a mk2 hgt 2001
| | smify999 | Stilo | 12 | 13-10-2006 17:29 |
| | cazzo_man | Stilo | 3 | 25-09-2006 22:55 |
| | braden | Stilo | 5 | 29-03-2005 12:14 |
