General How to Code the Blue Key from the Red Key?? Please Help
smurfboy0001
Hello,
I have a mk1 punto on a S Plate.
I have 1 working red key, and 1 working scruffy blue key.
I have now got a proper key, a blue one, which is not scruffy, and i want to code it so that i can use that one on a daily basis.
Can someone tell me how i code my new blue key from the red key?//
Smurf
  • swich on red key untill code light goes out
  • then swich on first blue key untill code light goes out
  • then swich on second blue key untill code light goes out
  • then swich on red key again until code light goes out
  • then wait beetween 4 and 9 seconds
  • then turn on red key again, if code light stays on they're programed, if code light goes off swich off and back on again, repeat until code light stays on then wait 15 seconds and try the blue keys they should be programmed
There must be a minimum of 2 blue keys maximum of 8 in order for you to program them :) so you're alright!
cheers!! one of my blue keys wernt working, working fine now :D
thats exelent mate ur really wiquied xxxx save loads of money xx.
how much is a red key cost?
and where do i get one i got two blue ones. cheers x
Does this only work with Code 1 keys? And if so, can you program an 'un-programmed' key with this technique?
TIA
