The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 27-07-2006   #1
Trader Rating: (0)
"Lights Check" Dashboard Warning Light
I'm new to Fiats and have just bought an 02 Punto Dynamic.
I drove it at night for the first time yesterday and noticed a warning light on the dashboard display that I didn't expect to see. Checked the handbook when I got home - it was the "Lights Check" warning light (an amber upside down lightbulb with an ! inside). According to page 36 of the handbook this comes on when "there is a fault in the lighting system". I checked all of the lights and everything was working fine, so I'm a bit confused as to what the problem might be.
I'd appreciate it if anyone can shed some light on the problem.
Many thanks.
Gethin
gethers is offline
Old 27-07-2006   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
Re: "Lights Check" Dashboard Warning Light
most likely to be damp in a connection, try wd40 on all connectors. you said all lights work, have you tried all lights at once, side/tail, dipped, full, fog front and rear, hazards (6 bulbs), brake & reverse. check all at once, sometimes this is the easiest way to spot a fault in the lighting circuit as any short will usually show itself (such as tail lights switching off with each idicator flash).
jug is offline
Old 27-07-2006   #3
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Can also be caused by wrong wattage of bulb fitted.
IF YOU'RE HERE TO MOAN OR SLAG FIATS - DONT BOTHER!
T14086 is offline
Old 29-07-2006   #4
Trader Rating: (0)
Thanks for the advice. I checked the bulb wattages, and they were as they should be - I thought that one may have gone high resistance, but they all looked pretty new (no silvering up etc.)
I shall WD 40 the connectors and also try all the lights on at once as you suggest.
gethers is offline
Old 29-07-2006   #5
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Your system covers side/tail/brake & number plate lights,double check number plate lights.
T14086 is offline
Old 30-07-2006   #6
Trader Rating: (0)
I've checked the bulbs, WD 40'd the connectors and checked the system with all of the lights on as suggested. All lights are working OK, but the warning light still remains on...I'm rather befuddled, to say the least. Any more ideas? Cheers
gethers is offline
Old 30-07-2006   #7
Forum Moderator
T14086's Avatar
Trader Rating: (0)
did you check the 'wattage' of each bulb?
T14086 is offline
Old 30-07-2006   #8
Trader Rating: (0)
Yes, I checked the wattage given on each bulb - they all looked pretty new, with no signs of darkening/silvering on the inside
gethers is offline
Old 02-08-2006   #9
Trader Rating: (0)
Finally found the culprit - it was a 5W tail light bulb which should have been 10W. Have now put the correct Wattage bulb in and everything seems OK. The rating wasn't clear on the bulb in question, so I missed it on the initial check.
Once again, many thanks for the helpful comments and advice.
gethers is offline
(T) Brake Warning light G Spag Bravo / Brava 2 16-06-2006 18:16
(T) amber warning light cazza410 Punto 1 02-05-2006 23:09
(G) Lights Warning Light jamie03 Punto 2 02-05-2006 18:21
(T) Injector Warning Light northernmonkey Cinquecento / Seicento 11 13-04-2006 19:47
(T) Injector Warning Light / Temp Gauge Probs chuck Bravo / Brava 20 29-10-2004 00:06
