The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 19-01-2006   #1
Trader Rating: (0)
Exclamation Fiat Punto Mk. 1 Sporting Compression
I have a Fiat Punto Sporting 1.2 16V on an S reg, It was burning oil, app. 5 litrs a fortnight. So someone suggested it might be numerous things but after a few simple diagnosis questions i narrowed it down to piston rings. I was told a wet and dry compression test would answer the question. So i went away, removerd all four plugs, did a dry and wet test 1 at a time on all four cylinders. Dry, 12, 12, 12, 12 bar.
Wet, 14, 14, 13, 13 bar.
Does this prove the rings are goosed?
brooky_uk is offline
Old 20-01-2006   #2
Trader Rating: (0)
Oldschool has donated!
Re: Fiat Punto Mk. 1 Sporting Compression
Before you go mad on repairs, take some Forte (only Forte!) engine flush, pour it into the oil circuit (forget what is written on the tin) and drive it as normal for a few days. Drain the oil with the Flush in it, replace filter and oil.
If problem persists then it won't be the piston rings.
Oldschool is offline
Old 20-01-2006   #3
Trader Rating: (0)
Arrow Re: Fiat Punto Mk. 1 Sporting Compression
You sure? Please see my Punto Mk 1 Burning Oil! thread from 1 week ago
Old 20-01-2006   #4
Trader Rating: (0)
The first thing i did when it started was do an oil and filter changed, not using forte flush. Made abseloutly no difference?!
(G) anyone have cinq sporting k&n panel filter??? beau Cinquecento / Seicento 0 22-10-2005 10:46
