The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 15-11-2005   #1
Trader Rating: (0)
Question Engine Management Warning Light Madness! Power Steering light Insanity!
My Punto is driving me mad... since buying it new in 2003 the power steering light has flashed on and off intermitently and the garage never founf the problem, just kept deleting faults! Now.. the latest problem last weekend the little yellow engine picture came on and I found it extremely difficult to start the car when hot... after three days of problems the light has gone off and is running normally. Any ideas???
Moneypenny is offline
Old 15-11-2005   #2
Trader Rating: (0)
Re: Engine Management Warning Light Madness! Power Steering light Insanity!
Aaaaarrrrrgggghhhhhhhhhhhhhh!
Old 11-12-2005   #3
Trader Rating: (0)
jiohnnyp has donated!
HI
I had VERY similar problem, wouldn't start when warm and power steering failure when restarted.
Changed RPM / TDC sensor. NO problems since.
£21:21 I think, 20 mins to fit.
Safe motoring
jiohnnyp
jiohnnyp is offline
Old 11-12-2005   #4
Burninator of threads!
faster4_tec's Avatar
Trader Rating: (0)
faster4_tec has donated! Mongolia
soon as the prob has been going on so long, it is still covered by warrenty so I would think fiat should replace your car since they cannot find the fault, the car has not lasted a resonable amount of time before un-fixable faults are occuring (i,e 3years) so stick it to them, and tell them they either fix it so it doesn't happen again (all at their expense as in they collect, fix and supply you with a courtesy car) or they replace your car with a new one.
I think when you buy a new car you should have the piece of mind that it won't cost your anythign in 3years, if not there is something sadly wrong.
Volvo for Life
faster4_tec is offline
Old 11-12-2005   #5
Trader Rating: (0)
What is the RPM / TDC sensor?? I have contacted FIAT who say it is not their problem...
Did you have the engine management light on too??? That what comes on when its having a not starting couple of days...
Old 11-12-2005   #6
Trader Rating: (0)
Hi
Rpm /TDC sensor is at rear of engine, above starter motor.
Jiohnnyp
jiohnnyp is offline
Old 11-12-2005   #7
Trader Rating: (0)
Thanks for that... did you have the same problem - did your engine management light come on?? It comes on every couple of weeks for a few days and I find it hard to start - then it will go off and be fine for a short while. The power steering light has always flashed on and off... usually when I am going in a straight line but I did have a problem last week where after I started the car the power steering light came on and the steering was heavy... then moments after that all the lights on the dash flashed on, then off and everything was normal... it's a strange car!!!
Old 11-12-2005   #8
Trader Rating: (0)
Is the Rpm /TDC sensor the same piece of wiring... I am not daft with engines but the electrical side is baffling, I prefer my old UNO
Old 12-12-2005   #9
Trader Rating: (0)
same here I like the old skool method.
My mate has a westfield sports kit car, with an overbored 1600 x/flow engine in it (now 1700cc and extensively modified, she's kicking about 145hp at the wheel's, and weighs 305KG's!!!!!) only thing electrical on it thats really required to get it going is starter, everything else is self propelled as it were.
It does have a few earthing probs as the chassis isn't great, so last weekend we rewired what there was back directly to the battery, job done, only thing that can fail is alternator.
Volvo for Life
Old 12-12-2005   #10
Trader Rating: (0)
Hi
Mang't light stayed on for a while after non start, run on motorway seemed to clear it.
My main problem was non start when warm. Fiat dealer no help, they wanted to change heater plugs,could explain to them that it started OK when cold!!
No steering/rpm-tdc sensor wouldn't be nomally remotly conected BUT, electricity plays some strange trick sometimes
Scan back thro' threads, some great info and helpers/ advisors on this site!
Safe Motoring
jiohnnyp
jiohnnyp is offline
Old 12-12-2005   #11
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Sounds like your car needs the speed sensor wiring modification.
T14086 is offline
(T) Punto "Bulbcheck" Amber warning light on dashboard Paul C Punto 24 10-11-2008 11:12
(T) New Punto Power Steering & Engine Management Fail shotter Punto 17 30-12-2006 12:45
(T) Engine Management System Light sh33n Punto 11 17-04-2004 22:21
(T) power steering problem saviogimmi Punto 2 03-03-2004 22:00
(T) Seicento Power Steering? dawozere Cinquecento / Seicento 7 27-02-2004 16:30
