Hello,
I just finished my 1st engine rebuild, tried to start it, but it just keeps cranking and won't start. When you push throttle pedal small explosion occurs and pops fire through throttle body (sometimes). Valve clearance good, spark plugs giving a good spark. Timing on crankshaft, camshaft and flywheel (0 degrees) all aligned. Before engine rebuild I needed to push throttle pedal and would take some time to start it. And yeah, I cleaned crankshaft sensor because it was full of oil and dirt. I hope I gave you enough info, if no, ask.
Thanks in advance.
Thanks in advance.
