Back again.
Eventually got one of the cables had to wait for one from China despite told it was in Britain.
Downloaded the Multiecuscan 3.6 program and ran it.
Read the manual configured the serial port to slow rate as advised. When installed USB end of cable operating sys Win10 seemed to pick it up immediately as no contrary warning.
Connected the cables to ECU and laptop and the power connections which I proved with multimeter.
Selected Punto55 from menu and Magneti Marelli 16F Injection from submenu. Turned ignition key to “on”.
Tried Multiecuscan “CONNECT”…got message Connection Failed Com 1 doesn’t exist.
Ran “SCAN” again no scanning took place and nothing written to file.
Tried the same with the other submenu Magneti Marelli 06F Evoluta injection but the first listed ECU is written in ECU box. Tried with ignition off and with engine running and no difference.
Where do I go from there considering my friendly garage could not connect to ECU either.
