| 1995 punto 1.1 heater blowing hot/cold hi guys!!!!! i've got a slight prob with my punto at mo, its a 1995 55s. the car is running great and doesnt seem to use any oil or coolant but the heater changes from blowing hot to cold air inside the car.... even when the car has been running for a bit!! apart from this and a crap handbrake i'm happy with it... i'm goin to sort handbrake out at weekend but any info regarding heater would be appreciated. thanks
| | #3 | ||
| Join Date: Oct 2003 Location: buxton the land that time forgot
Thanks: 1 Trader Rating: (0) | Re: 1995 punto 1.1 heater blowing hot/cold hmm yeah could be an air lock traveling around, hows the temp of the engine ?? is teh needle stable once warmed up or does it go up and down
__________________ 2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm | ||
| | #4 | ||
| Re: 1995 punto 1.1 heater blowing hot/cold hi, thanx 4 replies. im gonna drain and renew coolant/antifreeze on sat so hopefully that will cure it? if not then do u think maybe it could be the thermostat ? the car doesnt have a temp gauge (great one fiat)
| | #5 | |||||
| Forum Moderator | Re: 1995 punto 1.1 heater blowing hot/cold
| | #6 | ||
| Re: 1995 punto 1.1 heater blowing hot/cold This happened on my wifes car, and also was overheating, after having new radiator and new thermostat etc, it turned out to be the head gasket. apparently puntos are renowned for it. Ended up paying out for new head gasket 1 month later.
| | #7 | ||
| Re: 1995 punto 1.1 heater blowing hot/cold Yeah i think my gasket is going as it seems to be using coolant too, i top it up every 2 days with about half a litre it seems punto's are renowned for a lot of things so maybe i'll off load it and buy a non fiat or at least not a punto. shame really cause i wanted to really like this very poorly made and flawed car!! i miss my uno!!!
| punto heater blowing fumes into car | xrxr | Lets Talk FIAT | 5 | 23-09-2004 17:34 |
| | disah | Punto | 9 | 11-10-2003 22:49 |
| | savage1985 | Punto | 2 | 02-10-2003 18:44 |
| Fiat recalls - Punto [1] | roby76it | Lets Talk FIAT | 0 | 14-04-2003 02:50 |
