The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 02-11-2005   #1
meow
beau's Avatar
Trader Rating: (16)
beau has donated! United Kingdom
spark plugs, affect performance??
do spark plugs affect the performance of the engine? so basicly if i buy a cheap set will the car be any different if i buy a good set? if they do affect the performance what do people recommend for the punto mk1 60? cheers.
New car- **********
Long term project car- Punto 55
Previous car- Uno turbo
beau is offline
Old 02-11-2005   #2
Trader Rating: (0)
Re: spark plugs, affect performance??
mmm, they wont give you extra BHP if thats what you mean but they can make things more responsive.
I'd say dont spend silly money on them but keep to decent brands such as NGK and Denso.
1242 16v 119bhp/115lbft
GSR F10i, Supersprint Manifold/System, GSR Modified Map, Raised Compression, 3piece valve cut.
www.clubfirepower.co.uk
JamesMK2 is offline
Old 02-11-2005   #3
gregit's Avatar
Trader Rating: (0)
I remember when spilt fires first came on the market....
One mag did a review against I think, NGK Copper cores.... about quarter the price of the split fires.....
Guess which ones were better !!!
The cheaper ones....
Just get the gap correct on them.....
knackered HT Leads can cause problems as well as worn rotor arms and dizzy caps.... Do petrol puntos still have these though ? I drive a derv so wouldn't know !!!
2000 Plate JTD, Elx Punto 3 Door
It's bog standard
The Subaru Legacy was amazing...
I don't like
gregit is offline
Old 03-11-2005   #4
meow
beau's Avatar
Trader Rating: (16)
New car- **********
beau is offline
Old 03-11-2005   #5
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
super 4's have had mixed reviews on the forum.i personally didnt rate them highly in the turbo cinq but tom(i think)is happy with them in his 1.2 cinq
edit:also you can get them in shops for £19.99
custard is offline
Old 03-11-2005   #6
meow
beau's Avatar
Trader Rating: (16)
yeah i know im not saving anything from ebay, but i cant get to the shops, i hope there good, for all that money, my uncle said he can get them for less than £1 each so i hope it was worth it.
New car- **********
beau is offline
Old 03-11-2005   #7
i am
custard's Avatar
Trader Rating: (1)
should have said before,i have a set that would have probably fitted with less than 300 miles or running.just sitting in the boot
custard is offline
Old 03-11-2005   #8
fixitagaintomorrow's Avatar
Trader Rating: (0)
fixitagaintomorrow has donated! United Kingdom
Some people like Super 4's, some don't. Van Aaken fitted them to turbo cinqs, so I'd take that as a sign of approval. I thought they made the car run smoother, myself.
One thing I would say is that most people who have experienced problems when fitting Super 4's have found another underlying problem soon after, such as MAP, lambda or head gasket troubles. The plugs don't cause the problems, but may be more sensitive to an engine that isn't on top form.
Pete, Clubcento technical bod.
Links: turbo cinq, Bravo/a/Marea owner's club, Clubcento
fixitagaintomorrow is offline
Old 03-11-2005   #9
T.E.D.
Trader Rating: (1)
T.E.D. Jordan has donated! United Kingdom
I would say spark plug choice is a good one Bosch are pretty good but NGk and the quad spark's are really good also. TBH in my expereince and my dads vast 30 year experience of being in the mechanic business, if you buy a decent brand, you wont get any more BHP obviously, but it can make the engine run more efficiently, use 1 or 2 less mpg's sometimes, and a good set will not need replaced as oftern either. A good set can stop your cars cylinder head from foulinmg up and might not foul up as quickly on the spark plug either when under rich running conditions
Total Engineering Developments
T.E.D. Jordan is offline
Old 06-11-2005   #10
Trader Rating: (0)
The most important thing is for the plugs to be resistor type, otherwise the ecu can receive electrical spikes back through the ignition system.
AIRBAGS SAVE LIVES, WHAT WOULD YOUR FAMILY DO WITHOUT YOU? GET THEM FIXED.
NumanR is offline
Old 06-11-2005   #11
Fat pigeon... APPLE!
JonnyBoy's Avatar
Trader Rating: (1)
JonnyBoy has donated! United Kingdom
I've used Denso plugs (Q20PR-U, I think) on my Punto for years, they seem to give much better response than the NGK's that I used to fit.
I've never tried any of the "performance" plugs; to me, any plugs that cost more than £12 a set are overpriced!
Back in the day: mildly-modded Punto 55SX; rusty Ford Capri 2.0 Laser
Then: mk2 Focus Zetec Ti-VCT; same Capri, less rust
Now: Bravo Dynamic 150 MJet, in red, with extra toys same Capri, same rust
JonnyBoy is offline
(T) Spark Plugs and their effects on your car. NumanR Punto 3 24-05-2005 17:55
(T) Performance spark plugs? JonnyBoy Punto 12 01-08-2004 21:16
Recomended Spark Plugs Clover_F Coupe 6 20-01-2004 07:00
(T) Spark Plugs and Leads for 1.2 Sporting punto_T Punto 4 30-12-2003 21:33
Spark Plugs and Spark leads Sando Lets Talk FIAT 7 16-08-2003 20:25
