The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 01-11-2005   #1
Trader Rating: (0)
brake pad
HELP, how do i undo the caliper to change my brake pads on a 52 plate 1.2 8v punto, the obvious nut will not move and cant work out if its an allen key or a star key to undo it any ideas?
gazmaniandevil is offline
Old 01-11-2005   #2
thefishdude's Avatar
Trader Rating: (0)
thefishdude has donated! United Kingdom
Re: brake pad
hi i just looked in the haynes manual and if yoyu doing just a pad change you in luck there isnt actually any bolts to undo lol
at the bottom of the caliper there is metal pin held in with a small clips so it dont come out, it sais to pull the clip out then ther eis a metal pin you pull from the back, once that is out the caliper should pivot up wards so you can pull the 2 pads out.
2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm
thefishdude is offline
Brake pad sensor Gary Multipla 0 20-10-2005 18:28
(T) Brake Pad Problems!!!! chrisandrews320 Punto 4 24-08-2005 18:52
(T) brake pad info harrycat Stilo 1 15-04-2005 10:49
(T) Brake pad sensor cable apinnard Marea 1 10-12-2004 08:50
(T) Brake Pad Warning Light cscotson Bravo / Brava 0 14-09-2004 11:25
