| Punto Mk 2 CD player How many different CD Players are there ? I'd like to replace the existing Radio/cassette with a Radio/Single CD HU as i don't own any cassette tapes, but have hundreds of CD's. The car is a Mk2 1.2 ELX W reg/2000. The existing Radio cassette is a 'Mid' unit and powers the front and rear speakers , plus the Fiat bass unit in the boot. It has 3 plugs going in to it, these are: i) Power plug ii) Speaker plug iii) Yellow/Green/Blue plug, (iirc) only the yellow bit has wires though ( CDC Bus - is this for a CD Changer unit ?) Any idea of which model of Single CD head unit will fit so i can start looking out for one...
__________________ Current car: Punto Mk2 1.2 8v ELX (April 2000/W reg) Previously owned Fiats (over past 10 years) : Brava (facelift) 100SX on T plate Brava 1.6 SX on S plate Punto Mk1 75SX on L plate | |||
| | #3 | ||
| I had a CD-Changer fitted to mine in the boot. Was about £170 supplied by and fitted at my local car audio place back in 2001. Blaupunkt CDC-A08 that takes 10 CDs. After that I never used the tape player but didn't have to worry about it being broken in to steal...
__________________ Ex Teseo Blue Punto 2000W Mk2 ELX 8v Owner. 4.5 years and 60k miles worth of Punto joy. If you see W871TBL, let me know... | |||
| | #4 | |||||
| Re: Punto Mk 2 CD player
Thats what i plan to do with my new car. Saves you taking the CD front out and carrying it about as well!!
| | #5 | ||||||
I have seen another type of CD changer which is a 5 disc unit that mounts into the front Dash, howeve i don't think my car as the right shape/configuration of dash , or do you remove some of the vents ??? So basically, I own and have owned CD Changers and would now like to try a single CD/Radio HU. Thanks for replies so far , but getting back on track , has anybody got any idea's of which Blaupunkt Single CD players will fit my particular Punto, a part or model number would be great...
__________________ Current car: Punto Mk2 1.2 8v ELX (April 2000/W reg) Previously owned Fiats (over past 10 years) : Brava (facelift) 100SX on T plate Brava 1.6 SX on S plate Punto Mk1 75SX on L plate | |||||||
| | #6 | ||
| Join Date: Oct 2003 Location: buxton the land that time forgot
Thanks: 1 Trader Rating: (0) | Re: Punto Mk 2 CD player i think there is only one cd unit for the mk2 punto mk2.5 is wird differently i belive so dont get that. the yellow conector is the connector so the cars on board computer can check if you have inputted the radio code. this wire is not used if putting after market stereo in.
__________________ 2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm | ||
| | #7 | ||
| GP T-Jet Owner | Re: Punto Mk 2 CD player Go aftermarket with a fascia, get one with a faceplate that comes off and thats about as attractive to theives as prison
__________________ Sold: 02 (52) Sassi Grey Stilo 1.6 Active, Full Merkur Bodykit, MS Design Spoiler, 18" Lenso Shu Wheels, 50/40 Drop, Ragazzon Quad Exhaust Now: 07 (57) Crossover Black Grande Punto 1.4 Tjet 120 Sporting....Standard | ||
| | #8 | |||
__________________ Ex Teseo Blue Punto 2000W Mk2 ELX 8v Owner. 4.5 years and 60k miles worth of Punto joy. If you see W871TBL, let me know... | ||||
| | #9 | ||
| Hello m8 I have done exactly what you are tryin to do and had the same problems you are having! Firstly i take it on your tape player it says subwoofer on the tape flap? This is important as it is wired differently to those tape players which do not say this. If it does not and you try to swap it for the cd player it comes up with the message CANCHECK and so does not work. Secondly i have found that only 1 shape of blaupunkt cd players for the punto will fit the mk2's from 99 to around 02. This is the 1 which in its design is set back a little bit from flush with the dash. This is an example: http://cgi.ebay.co.uk/Blaupunkt-CD-R...QQcmdZViewItem The newer shape players are not compatible to the 99 to around 02 mk2 punto's as they are wired up differently. This is an example: http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1 I changed mine bout 3 weeks ago and took about 1 min to fit and its great the way it fits flush to the dash. Hope this helps Cheers Mike
| | #10 | ||||||
You need to be really strict about these types of HU's as the one time that you don't bother to remove it will be the one time that a thief strikes..... If you've just fitted a face off unit recently, I bet you're still not removing it every time in two years time.....
I've also been monitoring e-bay. Sometimes the photos that people take are not too good, but it looks like one of the models ( the later one) has a slightly more oval shape to it at the top, my current Radio/Cassette seems to be a little more angular. An OEM blaupunkt unit will be great, but I'm not gonna get too hung up about it, as another make with an adaptor plate will do, especially if it has a rotary Volume control - i hate buttons... An chance of a part number for the one that will definately fit ??
| | #11 | |||
As you quite fairly say tho they're easy to forget about, and it is annoying i guess having to take it off and put it back on, but when you consider the features you get on an aftermarket job, as apposed to something sold by Fiat......personally id find it hard to manage with a standard type thing
__________________ Sold: 02 (52) Sassi Grey Stilo 1.6 Active, Full Merkur Bodykit, MS Design Spoiler, 18" Lenso Shu Wheels, 50/40 Drop, Ragazzon Quad Exhaust Now: 07 (57) Crossover Black Grande Punto 1.4 Tjet 120 Sporting....Standard | |||
| | #12 | ||
| Re: Punto Mk 2 CD player £600 ! Yeah, i can see why you'd be careful about that, . To be perfectly honest I'm just after a simple functional unit to do the job and sounds OK. I have a pretty good Home Hi-Fi for serious music listening, Vinyl records are my real passion ( LP's not 12" dance singles ) A Linn 'Sondek' LP12 Turntable being my main music source. CD's are just a barely nessessary modern evil in my eyes... I don't spend a huge amount of time in my car, and the Punto is more my wifes car anyway , so if i did get a really good sound system installed , not only would she probably break it , but she'd not appreciate it either, sad but true i'm afraid...
| | #13 | ||
| GP T-Jet Owner | Re: Punto Mk 2 CD player Thats fair enough mate, everyone wants different things from the audio systems in there cars, fully understand your reasoning
| | #14 | ||
| Re: Punto Mk 2 CD player A quick question here guys, on the canbus system. Is the security coding system on the Fiat radios completely self contained within the units themselves or does the radio/CD Chnager have to interface with the cars ECU Computer in any way ? I'm asking to settle a disagreement i'm having with somebody...
| | #15 | ||
| Re: Punto Mk 2 CD player I want to place a mk2b radio/cd/mp3 in my mk2 punto. But i get the cancheck message. I would think that's because it's wiring is different. Mainly that will be because the mk2b radio can use the main punto display. but is there a converter iso plug on the market to get it to work.
| | mrme | Punto | 22 | 11-03-2006 14:49 |
| mk3 Punto MP3 Player in a mk2 Punto | jmw2002 | I.C.E | 1 | 07-01-2006 18:57 |
| | J_poshpromo | Punto | 12 | 28-05-2004 01:30 |
| 2003, punto active sport cd player | Darius32 | I.C.E | 1 | 30-09-2003 06:11 |
