The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 31-10-2005   #1
Trader Rating: (0)
How to top up brake fluid on Punto ?
Hi everybody,
I have just bought a new Fiat Punto from 2001.
The brake fluid level is a little low so I need to top it up.
However when I pour brake fluid in the brake tank, the fluid remains on the first part of the tank that is separated from the main part by a little "net".
This one seem to tight to let the fluid go.
has anybody got a trick on how to top up brake fluid ?
...I feel very stupid, but I can't do it !!
Thank you
Christophe
christophe is offline
Old 31-10-2005   #2
i'm bear :-)
Trader Rating: (0)
mathew has donated! United Kingdom
Re: How to top up brake fluid on Punto ?
hi, this is a filter to keep crap out of the reservoir.
if it doesn't go through the mesh then there is a small air lock - the air in the reservoir pushing/keeping the brake fluid on top of the mesh.
it is likely to seep through slowly, or if you gently tap with your knuckles the neck of the reservoir it will go through!!!
you may want to check around your brakes for evidence of cyclinder leaking as the brakes are a sealed system and the brake fluid level should not go down.
mathew is offline
Old 31-10-2005   #3
Trader Rating: (0)
Thanks Mathew,
I'll try this tonight.
Old 31-10-2005   #4
i'm bear :-)
Trader Rating: (0)
p.s. make sure the cap is off when you are tapping the neck, as obviously the air in the reservoir needs somewhere to escape to (i.e. the atmosphere!).
mathew is offline
Old 31-10-2005   #5
GhettoMoose's Avatar
Trader Rating: (0)
and if your cylinders are leaking, you'll know about it
Ghetto Moose - Running : 145BHP ,Punto GT2, BP270 Piper Fast Road Cam, Lemans DVK005 Dump Valve, Drilled Airbox with K&N panel filter. Next - De-Cat
GhettoMoose is offline
Old 31-10-2005   #6
Trader Rating: (0)
your brake fluid will go down as you brake pads wear.
1242 16v 119bhp/115lbft
GSR F10i, Supersprint Manifold/System, GSR Modified Map, Raised Compression, 3piece valve cut.
www.clubfirepower.co.uk
JamesMK2 is offline
16 or 17 inch wheels for Punto HGT / Abarth punto_power_nr_1 Lets Talk FIAT 9 25-06-2006 17:01
(T) punto brake failure!!! mathew Punto 23 15-11-2005 12:35
(T) Brake fluid light flashes during acceleration Minime Marea 11 09-11-2005 08:04
(G) Punto Sporting Mk2 TOP SPEED? symarshall Punto 40 28-02-2005 18:58
FIAT PUNTO FRONT BRAKE DISC KIT dave Auction Watch 0 08-05-2004 06:16
