Thread Tools
Old 25-05-2016   #1
Low mileage 60S
HI
Looking at a very low mileage (less than 2000miles a year!) 1998 Punto 60S It is an 8v & I have no service history yet. Does this engine has a cam belt?
What else to look out for apart from the obvious ....do all the electrics work!
It is relatively expensive, but if it is genuine it will be a good car for a grandson to start his driving career.
Punto1cab is offline Reply With Quote Quote
Old 25-05-2016   #2
769cc Mayhem!
Didge3's Avatar
Didge3 has donated!
Re: Low mileage 60S
Yes it has a cambelt, the FIRE 8v (55, 60, 75) engines are incredibly easy to work on, cambelts are every 72k miles or 5 years I think. Probably safer to get it done unless there is proof of it being changed.
Check electrics as you've mentioned, check for rust around the rear arches, the sub frame, floors and sills are the big areas, if these aren't crusty then anything else that may be wrong with the car is most likely a cheap fix
FIAT-LESS
Didge3 is offline Reply With Quote Quote
Old 25-05-2016   #3
Re: Low mileage 60S
Quote Originally Posted by Didge3 View Post
Thanks, I'm having a look tomorrow. Mot's check out & no advisories ...little old lady car I think, past 7 years 250 miles a year! Just need to get the price down...the dealer is an optimist....aren't they all!
Old 27-05-2016   #4
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Snowboard Slalom Champion, Skate Boarder Champion
Re: Low mileage 60S
totally agree with Didge, if its solid shell then just buy it. its nice to get a mechanically sound car but the more important thing is that its not all rusty (rust can also be fixed obviously but its very time consuming and expensive if you cannot weld and paint yourself)
60s is a pretty basic model so not a huge amount to go wrong electric wise, no central locking, no electric windows etc. The very first car i owned was a 60s - basic motoring at its best (Y).
I would advise a full service if you purchase it without history.. including:
-belts, idlers and tensioner
-waterpump
-all fluids and filters (inc. fuel filter)
-check and replace as necessary plugs, leads. consider renewing the coil packs
-some would argue pointless but there are a few sensors that are easy to swap and cheap which are pretty crucial to healthy running, crank sensor, temp sensor, rad fan switch
-check all rubber parts for fatigue and cracking, suspension bushings, engine and gearbox mounts, flexi brake lines etc
Sounds like alot of stuff but its all simple stuff and inexpensive to buy.
Charmander - Panda Mania 1242 mpi 8v - thread
Unnamed - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT
blu73 is offline Reply With Quote Quote
Old 30-05-2016   #5
Smile Re: Low mileage 60S
Well we bought it. Runs well, filthy under bonnet with dust & mud! Paint absolutely flat/dead, but will polish up. Cleaned up well, no rust anywhere, a few niggles of course:
The horn doesn't work, nor does the interior light, Fuses ok...where next to look ??
The original radio had the wrong removable face panel, but I still had one from Mrs H's Cabrio, popped that in & we have a working radio!
Rear screen wash pipe was disconnected & washing the inside of the hatch. Easy, if fiddly fix.
Rear seat base (nice fabric, blue no 224) has split at a seam...anyone got one they don't need?!
I will get it on a ramp tomorrow & check out some of the points previously mentioned, but "ain't broke, don't fix" will be the plan as I run it around a bit.
Old 30-05-2016   #6
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Re: Low mileage 60S
ah nice, get some pics up
for the horn i would just check the wires near the horn, often corroded inside under the actual plastic coating. But just get some wire and stick 12v directly on the horn to check it works first, then strip some insulation of the wires to see if its really bad, if so keep stripping til you find nice clean copper wire and chop and add a new bit of wire if required to get enough length back.. Failing that move back to the horn switch and check that is working with multimeter - my money is on corroded wires though.
Old 30-05-2016   #7
Re: Low mileage 60S
Quote Originally Posted by blu73 View Post
Thanks...haven't found the horn yet!
Old 30-05-2016   #8
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Re: Low mileage 60S
It's been a while but if memory serves it's on the front. In front of the radiator so tricky access. But also why the wires get corroded
Old 30-05-2016   #9
Re: Low mileage 60S
Name:	ImageUploadedByFIAT Forum1464619411.342228.jpg
ID:	168417is this the same blue cloth ? they need a good clean , no holes .free if you want them , you can have the whole car if you've got a trailor 👍🏻
Steve gt is offline Reply With Quote Quote
Old 30-05-2016   #10
Thumbs up Re: Low mileage 60S
Quote Originally Posted by Steve gt View Post
Attachment 168417is this the same blue cloth ? they need a good clean , no holes .free if you want them , you can have the whole car if you've got a trailor 👍🏻
Thanks I will have a good look tomorrow & check the match!
David
Thanks Steve gt thanked for this post
Old 31-05-2016   #11
Re: Low mileage 60S
Quote Originally Posted by Punto1cab View Post
David
Well they are very close...I have a brochure from that era & I think your seats are Blue Cloth 234... whereabouts are you? I am Stratford on Avon.
I don't think I need the whole car....but!
Old 31-05-2016   #12
Re: Low mileage 60S
Well I have had a peer through the grille & a feel around, but I can see nothing! Can't see it on the Cabrio either, but that works! I'll have to get Mrs H to blow the horn with my head under the bonnet!
The 60S is really uncluttered ...no spots, no PAS, no ABS! Still can't find it
D
Old 31-05-2016   #13
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Re: Low mileage 60S
OK looked this up..
Quote Originally Posted by Haynes Manual
The horn is mounted on the lower edge of the front left hand wing, behind the front bumper moulding. To gain access, remove the screws and detach the hatch from the wheel arch liner.
Reach through the aperture in the wheel arch liner and unplug the wiring from the horn at the connector.
Old 31-05-2016   #14
Re: Low mileage 60S
OK looked this up..
Many thanks. I'll go have a furtle!
David
Old 31-05-2016   #15
Re: Low mileage 60S
Hi David , the seats are in a 1998 60 s not sure of the code , I am in Chesterfield , think we have spoke before at Stanford hall show .
Thread Tools
(G) Low Mileage 4x4 Anyone? Palio Panda (Classic) 31 11-02-2015 22:27
Panda (Classic) Very Low Mileage Selecta panda1408 Auction Watch 3 09-05-2010 17:22
(T) Low mileage service RichDoblo120 Doblo 3 27-10-2008 01:13
1989 mk1 60S 'Eleganze' Uno - v. low mileage & cheap! Chas Uno Auction Watch 5 08-04-2007 10:26
(T) Punto 60S low at rear? FriedEggs Punto (Mk1) 1 22-11-2004 00:24
