Just put a new clutch, brakes etc in my 99 Cabrio, Renewed seals on drives as well as rear crank seal. All back together, started no problem, into gear and bang!, Oil out of box, a good few F>>KS etc and then left it alone for a few days. Took box out today, one of the sun gears out of housing through into bell housing. I suspect that the circlip cracked when I replaced the shaft and caused the problem, found the two pieces of it in the bottom of the diff. Plastic speedo drive well chewed as well.Few pics attached. Isn't life a bitch!
