The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 03-11-2003   #1
Trader Rating: (0)
Airbag warning light stays on
The airbag warning light on the dash stays on (2000 model punto). This happened after accidentally removing the airbag fuse. The light remains latched on since. Any tips? Will disconnecting the battery for a coupe of hours do the trick?
Dermo
coupe2004 is offline
Old 22-12-2003   #2
Trader Rating: (0)
Hi. Did you solve the problem already. My Punto does the same except that the thing that triggered the light was to move the passenger seat back.[?]
Bernd5179 is offline
Old 22-12-2003   #3
polecat's Avatar
Trader Rating: (0)
polecat has donated! United Kingdom
When the airbag power is dissed the ECU latches in a fault. You need to go to a garage with a diagnostic box to get the ECU fault codes reset.
Got more additives than fuel in my tank.
polecat is offline
Old 24-12-2003   #4
Trader Rating: (0)
Did that today. The big question there was where to find the connector. Finally found it. It is located behind the plastic cover on the very left side of the steering wheel where there is a small tray, about knee high. Everything else took a minute. Thanks
Old 31-12-2003   #5
Trader Rating: (0)
this has happened on my car also, can i fix it myslef? cos i am booked into the garage but i cant really make it cos of school etc????
wicked_phucker is offline
Old 31-12-2003   #6
polecat's Avatar
Trader Rating: (0)
You need an ACR and car code pod to fix it yourself. £300 to £400 to buy. (If anyone knows where I can get a cheap one i'm interested).
The garage will be able to reset it in a minute, after spending half an hour looking for the right plug.;)
Dave.
So much to do, so little time.... and Totally Skint!! :(
polecat is offline
(G) AIRBAG warning Light joes Marea 8 29-09-2004 22:43
(T) Punto Airbag Warning Light tiff123 Punto 4 25-05-2004 04:19
(T) Airbag warning light on eldib Punto 6 29-03-2004 08:10
Airbag Warning Light keggers Ulysse 11 12-12-2003 17:57
