The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 16-10-2005   #1
a fiat with style!
puntomk1's Avatar
Trader Rating: (0)
puntomk1 has donated! United Kingdom
viewed a punto gt today
went to see a punto gt today and theres a couple of problems with it the first one is that the power steering is leaking fluid been told it might need a new pump? and the other is that the cam gasket is leaking abit so needs a new gasket.i would have to drive it 1 hour to get home aswell.
what u rekon guys?
puntomk1 is offline
Old 16-10-2005   #2
Banned
Puntoboy's Avatar
Trader Rating: (0)
Puntoboy has donated! United Kingdom
Re: viewed a punto gt today
cam cover gasket is common.
easy and cheap to replace. also use nylock nuts to prevent it from happening again.
the PAS steering leak, well all depends if it is the pump.
i've had to replace pipes on my GT, never a pump. i cant see it being the pump, you need to check further.
Puntoboy is offline
Old 16-10-2005   #3
a fiat with style!
puntomk1's Avatar
Trader Rating: (0)
well they said when they fill the reservior up for the steering it works fine then once the fluid as leaked out its obviously stops workin again.could be a leaking pipe
do you think it would be safe to drive back with the oil leak? they said its not that bad.
puntomk1 is offline
Old 16-10-2005   #4
Banned
Puntoboy's Avatar
Trader Rating: (0)
yes, but disconnect the pipe from the pump to the rack. this prevents air being forced into the rack, possibly causing more damage.
there are 3 pipes in the system, between the reservoir, pump and rack.
Puntoboy is offline
(T) Fiat Punto ECU Wiring Diagrams arseofbox Punto 8 20-03-2006 20:15
i argued with a chav today bout punto gt beau Leisure Lounge 1 27-12-2004 23:31
(G) Punto or Phut-Phut-Phut-O! McBain Punto 12 30-10-2004 21:10
