Hello,
I'm new to the forum but could not find a thread with a definitive answer, so here goes:
My horn was working very sporadically. Only when the steering wheel was turned the right way, and also some times when I didn't push the button. Of course this is very annoying and it will not pass MOT like that, so I installed an auxiliary horn button. The horn works every time when i press the button I installed, but today it also went off when I didn't use the button. Quite annoying...
I know it's because I could not find the original switch wire that goes to the steering wheel.
I took off the buttons on the steering wheel and put some electrical tape over those contacts, so that it wouldn't go off sporadically anymore (or so I thought).
Turns out I was wrong.
I do not have the wiring diagrams nor could I find them. What I discovered myself is in the picture below. The other contacts on the horn relay will go to the ground and horn respectively I assume, but I did not check this.
Any help would be appreciated,
Bob
Edit: My Punto is a petrol 60s with 58hp. This is probably important..
Bob
