Many Thanks...all clear (ish) now!!
GRRR. All fitted & still hesitating occasionally! Now wondering if one of the new coil packs is faulty...clutching at straws! My local garage is good, but doesn't have the diagnostics for this (early) engine. there is an (ex Fiat dealer) indie mechanic quite local, so I may have to take it to him.Many Thanks...all clear (ish) now!!
Strangely enough, that was my very first thought! Then I got seduced by all the electronic trickery! There is quite a lot of whining & clicking from the back end after you switch off...is that normal, I can't remember?my next guess would be fuel pump
Thanks...Have to find the filter now!you asked towards the start of the thread about the fuel filter, did you ever get that changed/checked?
don't know the cabrio myself but my hesitation problem was fixed in the end by a new coilpack and/or fuel filter, easy to do and cheap as well. good luck anyways
Could still do with a decent Fiat indie in the Warwickshire area!
there is fuel filter on mk1, just not on 55
I started this thread back in July last year!for a kick off no punto has a carb..
all puntos, no matter what model, have an inline filter. But not all of them have the same filter.
look under the car same side as the filler, slightly forward of the filler and you should see it, pretty obvious.
Guess what? It came back!nice, all that to find out you had bad spark plugs
