The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 11-10-2005   #16
GhettoMoose's Avatar
Trader Rating: (0)
Re: Am I too hard on my punto?
Thats why Ive been through 2 clutches, 2 gear boxes and a clutch slave cylinder in the time i owned a punto
Puntos never did idle well!
Ghetto Moose - Running : 145BHP ,Punto GT2, BP270 Piper Fast Road Cam, Lemans DVK005 Dump Valve, Drilled Airbox with K&N panel filter. Next - De-Cat
GhettoMoose is offline
Old 12-10-2005   #17
Trader Rating: (0)
Thumbs up Re: Am I too hard on my punto?
I see some conflicting information here.
On the one hand I'm told to change gear around 3500rpm to 5000rpm which would mean I'm doing somewhere closer to 20mph a gear rather than the slightly over 10ish (or 2500rpm) at the mo (at least for changes from 1st, 2nd and 3rd).
Then on the other hand, I read that one person that has been doing 20mph per gear has had to go thru a couple of clutch and gearbox changes because of it (or am I reading that wrong G.Moose?)
So, is my method (2500rpm) going to cause me to need repairs/replacements sooner than the 3500+rpm method?
( Taking into account that this is my first ever car, only had it about 2 months, I really don't know dick about this kind of stuff )
http://img76.imageshack.us/img76/7674/ffsigtk9.jpg
[timko] is offline
Old 12-10-2005   #18
jenks69's Avatar
Trader Rating: (0)
Looks like we all have differant driving styles and techniques! I have hit the rev limiter a couple of times in 1st, often if I don't rag the nuts off it when I go to 2nd its way too slow to pull out into moving traffic. But if I can get to 20ish in 1st then 30ish in 2nd I can at least get into moving traffic without causing a problem to the poor person behind me! Once I am at the speed limit of the road then I'll be in what the highest gear possible to keep revs down.
Hopefully once I have fitted the rev counter I'll have a better idea, I'll drive like I normally do for a day or two and see what revs I am doing, if I end up like this:
Then I guess I am expecting too much from my poor melvin!
jenks69 is offline
Old 12-10-2005   #19
Trader Rating: (0)
The FIRE engines seem prerry robust, I had a 1.2 Punto for 2 years, covered about 17000 miles in it, no serious mechanical failures, and I ragged the nuts off it on a daily basis. Very very very good engine, it was the best thing about the car!
The Trooper is offline
Old 12-10-2005   #20
Trader Rating: (0)
I took my punto 60 sx to bout 40 in second, and bout 60 in 3rd ( on a private road) and ever since my gear box has been getting really bad and now i need a new one!
Peteg is offline
Old 12-10-2005   #21
jenks69's Avatar
Trader Rating: (0)
I think the general theme here is rag punto bits break, looks after punto and rag it, when everything is warmed up, regular fluid changes etc and they can take a fair bit of abuse.
jenks69 is offline
Old 12-10-2005   #22
Trader Rating: (0)
I had a N reg 55s. I did tend to drive hard and once managed to get 105mph whilst driving in France.
Very quick and hardy 1.1 engine, it seemed the more i thrashed it the more reliable it was
Im usually in 5th when i hit 40/45 mph.
dazz666 is offline
(T) Fiat Punto ECU Wiring Diagrams arseofbox Punto 8 20-03-2006 20:15
(T) engine swaps fixitagaintomorrow Cinquecento / Seicento 0 31-12-2004 01:17
(G) Punto or Phut-Phut-Phut-O! McBain Punto 12 30-10-2004 21:10
Fiat recalls - Punto [1] roby76it Lets Talk FIAT 0 14-04-2003 02:50
