the pcd of a punto (and most other fiats, except some newer ones e.g grande punto) is 98mm
Center bore (hole in middle of wheel) is 58.1mm
Offset for a mk1 is 38mm, you can give or take a few mm of offset with out a problem
you can however fit wheels with a 100mm pcd with wobbly bolts as long as the center hole is the right size, this can be safely reduced on most wheels with spigot rings
