The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 31-10-2003   #1
bazzasmithkins's Avatar
Trader Rating: (0)
where is Temperature sensor on the SportingMk2
<font face="Comic Sans MS"></font id="Comic Sans MS">
can anyone tell me where the temp sensor is on the mk2 sporting, as i bought a mod from ebay and cant figure out where to put it. pleeeeeze help!!!!!!
mail me @ chris@blackburn2311.fsnet.co.uk
bazzasmithkins is offline
Old 01-11-2003   #2
Trader Rating: (0)
not shure but try the radiator,the thermostat housing (or in the top of the block beneath the water pump if your pump is external)!
not much help i know!!! (it looks like a nut with elec connection on top!)
Punto 1.6 sporting is offline
Old 01-11-2003   #3
Trader Rating: (0)
If Its an 1.2 8v engine, its in the back of the inlet manifold on the passenger side.
FiatExpert is offline
Old 01-11-2003   #4
Trader Rating: (0)
that sensor!
will be a 1242cc 16v though!
Old 01-11-2003   #5
Trader Rating: (0)
Either still in manifold or in thermostat housing 2 pin green sensor
Old 01-11-2003   #6
Trader Rating: (0)
if its the Air temp sensor it will be in the inlet manifold!
if its the thermostatic switch it will be one of the above!
take it that its the air temp so that it over fules or something trick like that? ;)
Pls explain as i may try one!
Old 01-11-2003   #7
Trader Rating: (0)
If its the air temp sensor/Pressure sensor its a 4 pin black colour sensor on the manifold, also the coolant temp sender can be in manifold a green coloured sensor with 2 pins. It dosent have a thermostatic switch for the cooling fans there are controlled from ecu all of the one sensor... not two or three like old vehicles.. Didn't get last message
Old 01-11-2003   #8
Trader Rating: (0)
so how dose that work ? if the inlet manifold is sucking in cold air how dose it ever think the air is hot and run the fan ? all new to me my 1242 16v has both!
Old 01-11-2003   #9
Trader Rating: (0)
In the back of the manifild it has coolant form cyl head running through it
Old 01-11-2003   #10
Trader Rating: (0)
know coolant run inio it but did not know the senor was there!
Your the boss !
Punto Sporting With Abarth Kit & A Few Trick Bits
Old 02-11-2003   #11
Nothing's Impossible!
brickfoot's Avatar
Trader Rating: (0)
brickfoot has donated! United Kingdom
if it's a little resistor mod you have, you need to have a look along the air intake route to find an electrical connector, usually has 2 wires coming from it. The resistor mod u'll have, tricks the ECU into thinking the air is cold and chucks in more fuel. Not really recommended as it'll void your warranty. a mate of mine had the ECU warning light on his dash light up and took it to fiat, said there was a problem internally in the ECU and needed replacing. They found the thing attatched and the b@stards voided the warranty! he had to pay up to fix it. BE WARNED.
Coming soon: Cinq lower than a Prostitute's knickers!
brickfoot is offline
Old 02-11-2003   #12
Trader Rating: (0)
thats the one! so did it work well? and do you thing it f#cked your mates car?
Old 02-11-2003   #13
brickfoot's Avatar
Trader Rating: (0)
Not really. fuel consumption increased marginally but nothing on performance. When fiat had the ECU connected to their diagnostics machine, it failed to get a reading and when they found the mod, they removed it and still got no reading on the machine. Dodgy mod = bye bye warranty basically. Better spending money on a superchip, those Don't void the warranty.
Old 02-11-2003   #14
Trader Rating: (0)
I got My punto Chipped and got told by fiat i did !
dont think i will bother with that mod then!
Old 02-11-2003   #15
brickfoot's Avatar
Trader Rating: (0)
It shouldn't. Superchips are a professional installer and as long as it's done properly, won't void the warranty.
(T) Marea external temperature sensor scanny Marea 2 30-04-2004 04:13
(G) UNO 999 cc temperature question Sreenath B.H Uno 4 08-04-2004 19:16
(T) Mk1 55S Temperature Guage blahmartinblah Punto 0 03-10-2003 18:45
(G) Fiat Uno, Engine temperature problems pikkumies Uno 3 29-08-2003 20:34
(G) Missing handbook and engine temperature issues Lestat Cinquecento / Seicento 2 13-02-2003 22:58
