| Ok, bit of a random one.. i have this really really annoying squeak going on at the back of my car,... now at first i thought it might be the exhaust shaking away when i went over bumps..however, logic has brought me to thinking its possibky my suspension as its only really obvious when i turn a certain way, and the car leans slightly.. in a straight line its fine, and at speed theres no sound.. When its been jet washed it seems to be ok for a short while, but eventually starts up again (i assume when it dries out?) Its like a high pitched squeak, quite a rapid noise, not a groan, like i'd expect suspension probs to sound more like.. i dunno.. has anyone else experience similar probs or knows a solution? Thanks C x
| Was VXR enough :( | Re: Squeak! Yep, annoying isnt it! Its the handbrake cable rubbing on a securing mount near the back wheel- have a look around there and you'll find it. Stick some grease where it comes into contact with the mount
__________________ Fiat Punto Active Skoda Fabia vRS Vauxhall Astra VXR SEAT Ibiza 20VT FR Renault Clio 182 & Honda CB600FA Hornet | ||
| | #4 | |||||
| Re: Squeak!
I will defiantely have to get some hot looking alloy's now, if only for the excuse to whip the wheels off.. Thats a big help..Thank u Cx
| | #5 | ||
| Re: Squeak! By the way... hot car. ![]() Looove the wheels.. Mine's black..
| | #7 | ||
| Re: Squeak! Really? aw.. so what u got at the mo?
| | #8 | ||
| Forum Moderator | Re: Squeak! No need to take wheel off or raise car,just need 2 cable ties,wire cutters(to cut off old cable ties) & some grease.
| | #9 | |||
__________________ Fiat Punto Active Skoda Fabia vRS Vauxhall Astra VXR SEAT Ibiza 20VT FR Renault Clio 182 & Honda CB600FA Hornet | |||
| | #10 | ||
| Re: Squeak! - update Just to update on the squeak, i got underneath the car and had a good look around, did what u suggested, got all greased up.. lol... and hey presto, no more squeak! Just to say thanks for the advice! Cx
| | #11 | ||
| Forum Moderator | Re: Squeak! Unfortunally it will return after a extended period,however I like many others do this as a matter of course at a service even though its not on te service list but its such a common problem it might well be on the list soon!
| | #12 | |||
| Was VXR enough :( | Re: Squeak! Glad you got it sorted Claire (For now anyway)
| | #13 | ||
| Re: Squeak! Yeah i figure it'll be an onggoing thing i'll need to sort, but at least i know what it is and how to sort it! So thank you.
| | #14 | ||
| Re: Squeak! I had this annoying squeak on my Punto and had i to the Fiat deaer three time for them to apply a "special hard grease" which only stopped the squeak for around three weeks, finally they admitted there was a problem with the type of axel used and i got it booked in for a new type replacement axel 8 months ago, no more squeak and it was done under the warranty!!!!
| | #15 | ||
| Re: Squeak! That would have been for a squeak from the pivot bushes, these can sometimes be stripped and a special grease applied or if too bad require the rear axle replaced.
__________________ AIRBAGS SAVE LIVES, WHAT WOULD YOUR FAMILY DO WITHOUT YOU? GET THEM FIXED. | |||
| | chrism01 | Punto | 2 | 23-09-2005 13:05 |
| | Rachcento | Cinquecento / Seicento | 3 | 31-08-2005 20:58 |
| | Cooter | Cinquecento / Seicento | 8 | 05-06-2005 13:32 |
| | ChrisF | Stilo | 11 | 19-05-2005 23:44 |
| | paulsmith109 | Punto | 5 | 29-04-2004 15:05 |
