| Mirrors? Hi there I bought a 2000 X reg punto 1.9 JTD ELX but im struggling to move my side door mirrors? Im moving the little toggle but nothing happens? Can some1 plz help me so i know if im bein a muppet or if they broke? Cheers Mike
| Check OK | Re: Mirrors? I'm assuming the ELX has electric windows?... Does the mirror make a buzzing noise when pressed (this would indicate the connection to the mirror is still live)? Check to see if anything is stopping the mirror from moving; e.g. stone, spider, dirt etc. Could possibly be the electric motor, these are relatively cheap and easy to replace. Does the passenger side mirror work ok, this would eliminate fuses out? Hope this helps, Matt
__________________ ![]() 2002 Stilo Dynamic 115 JTD 3 door Grigio Steel. Full Leather, CD Changer, Fiat Alarm, Parking Sensors, De badged, Body Kit. Team JTD. Now with Roof Rails! --------------------------------------------- A Day Without a Smile is a Day Wasted! | ||
| | #3 | ||
| What's the worst that can happen? | Re: Mirrors? The fuse I think is the same one as other stuff including the indicators so I would imagine that means that's ok. If it has manual mirrors and the knob doesn't move the mirror then it must have broken the connection (happened on my uno). Don't know how easy it is to fix because I just leaned out and pushed them instead! I've never been in an electric mirror punto but on some cars you have to push the knob in or turn it around to select which mirror to move before you push the knob around to move it, so a long shot but just an idea.
__________________ "The new rules are very simple. The FIA will keep them to themselves until such a time as Ferrari needs them" - Patrick Head | ||
| | #4 | ||
| I wouldn't jump to the conclusion they're electric mirrors. I found the range of adjustment to be small, and therefore if you can't get the angle you need, try moving the housing by hand before tweaking with the little joystick. Since I had a wing mirror knocked off (and which I replaced before I crashed into someone due to not having a mirror), I know that the control is down 3 small cables which link directly from the joystick ionto the mirror. If you can't adjust it then it could be jammed up completly, and then you'd be looking at new mirror units ![]()
__________________ Ex Teseo Blue Punto 2000W Mk2 ELX 8v Owner. 4.5 years and 60k miles worth of Punto joy. If you see W871TBL, let me know... | |||
| | #5 | |||||
| Re: Mirrors?
| | #6 | ||
| Re: Mirrors? my mirrors are manual not electric . mine did the same after someone knocked them , when i took it in for its mot they fixed it - foc , so i can't see it being a big job 2000 x reg fiat punto 1.9jtd elx
| M3 mirrors on a mk2 | ger | Punto > Styling | 9 | 05-09-2005 19:54 |
| mirrors | ger | Punto > Styling | 17 | 08-08-2005 20:36 |
| Punto Mk2 Wing mirrors! | mastermick70 | Punto > Styling | 6 | 09-04-2005 18:01 |
| M3 Mirrors on Punto base plates. | Big Blue | Punto | 7 | 13-02-2005 17:47 |
| my mirrors on e bay!!!!!! | fimmo | Cinquecento / Seicento | 3 | 16-01-2004 05:06 |
