F FPUNT098 New member Joined Jan 15, 2015 Messages 4 Points 1 Jan 15, 2015 #1 DOES anyone know which of these is the radio fuse?
F flisko ` Parked in the garage Written 5 guides Joined Jan 20, 2013 Messages 6,151 Points 1,228 Jan 15, 2015 #2 look on the plastic cover to see which one or keep removing them 1 by 1 till you find one
J judderbar Patron member Uploaded a resource/download Joined Jan 11, 2015 Messages 2,251 Points 514 Location Helsinki Jan 15, 2015 #3 FPUNT098 said: DOES anyone know which of these is the radio fuse? Click to expand... If the following is correct, https://www.fiatforum.com/punto-ii/213827-fusebox.html?p=2281840 In the main block of pictured fuses it is in the top row, 4th fuse along. This fuse also covers the courtesy light, luggage area light and others. FYI the second fuse in row 2 for the heater is listed as a yellow 20amp and you have a green 30 amp Last edited: Jan 15, 2015
OP OP F FPUNT098 New member Joined Jan 15, 2015 Messages 4 Points 1 Jan 15, 2015 #4 judderbar said: If the following is correct, Thank you. I will try that Click to expand...
OP OP F FPUNT098 New member Joined Jan 15, 2015 Messages 4 Points 1 Jan 16, 2015 #5 You were right thank you
