| lowering hi new member here just bought a new punto elx hopefully going to have 16's on.was wondering how much i can get away with lowering it. cheers folks;)
| You can lower it 35mm easy. I had 16"s and lowered it 35mm and there was no rubbing or catching even with people in the back. Th only thing you may need is 3-5mm spacers on the rear.
| | #3 | ||
| With the correct offset you can lower by 60mm+ obviously without people in the back. www.puntoforum.co.uk Evil-Punto AKA Evilution.
| | #4 | ||
| as evil said 60mm should be ok ! if you think you will have people in the back just dont cut the rubber bump stops ! my mk1 is down 60 on 16's and i did not cut them by much no rubbing ex ex even the front when turning! however i did add a strut brace to cope with the shocks!
| | Cornish Bravo | Bravo / Brava | 3 | 30-07-2004 00:26 |
| | FAT BrAvO | Bravo / Brava | 13 | 07-05-2004 19:00 |
| Lowering | cioccixxx | Lets Talk FIAT | 7 | 05-05-2004 05:22 |
| | MrBravaLava | Bravo / Brava | 4 | 28-09-2003 19:03 |
| | arseofbox | Cinquecento / Seicento | 3 | 18-07-2003 00:11 |
