Did it break out, or in?
If the broken piece was hit outwards, then as Dave says, something on the diff has come off and been punched through the casing. There are previous issues on here where the bolts holding the crown wheel on have come loose and done this.
Options:
Replace gearbox. Take care to get the right one to match the original.
Strip gearbox to inspect for cause and other damage. Weld up casing and replace displaced bolt. Rebuild. May be lucky.
If the break was from the outside, then something in the clutch housing has been smacked against the casing. Cause should be more obvious.
