The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 24-08-2002   #1
Trader Rating: (0)
Power loss - fule pump problem??
Hello!
I own a Punto 60S (year 1994). For about 2 months I cannot reach speeds greater than 120 km/h. I have measured the TDC sensor and it has only 599 ohms (650-720 ohms in the car repair manual).Also the fuel pump is buzzing if you listen it carefully.
Should a buzzy fuel pump or the TDC sensor cause my power loss?
Radu
raduvacaru is offline
Old 24-08-2002   #2
fixitagaintomorrow's Avatar
Trader Rating: (0)
fixitagaintomorrow has donated! United Kingdom
The best thing to do is to take it to a Fiat dealers and ask them to either read the fault codes or run a diagnostic test to see if anything has failed. It could be the TDC sensor, Lambda sensor, MAP sensor, or fuel filter / air filter even.
Lambda sensors on Cinquecentos (very similar design) seem to have quite a short life.
Sorry it's a bit vague, but hope it is of some help.
Pete.
Cinq sporting
http://mysite.freeserve.com/close_to_cracking_up/
fixitagaintomorrow is offline
Old 11-09-2005   #3
Trader Rating: (0)
Smile Re: Power loss - fule pump problem??
change your fuel filter first its the cheapest and well worth a try
pitstopdave is offline
(G) Uno ie 1.0 999cc fuel pump problem jrrsteve Uno 5 06-08-2008 22:06
(T) Power Steering problem ELX(8v) 2000 reg NickT Punto 3 04-07-2004 02:03
(T) Fiat Brava Sudden loss of power Tangerinedreamer Bravo / Brava 2 19-04-2004 05:55
(T) Power rev loss....? pokerface Cinquecento / Seicento 3 14-03-2004 02:11
(T) Power Loss? Sei-Mad Cinquecento / Seicento 8 14-01-2004 03:09
