The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 07-09-2005   #1
Trader Rating: (0)
Exclamation Squeeling brakes, urgent
I drive a 200o plate W reg 1.2 8v elx punto. My brakes recently needed doing. So off i went to charlie browns. This is when the problems started. I got charged 134 pounds for new disk brakes and pads and the rear ones cleaning up and stuff. From then on i had a squeeling noise. The noise actually only happens on the left tyre when i turn right. When i turn left it shuts up. So i went back down. They said to leave it til it gets worse, which cud take up to 3 months. So i went to kwik fit, who own charlie browns. They stripped them down for me, cleaned them up again and put them on saying there was alot of dust on them. Not sooner had i left the garage did they start. I gave them a week. Went to charlie browns and demanded new ones on. They have put me new brake pads on which until now have been fine. The quietness lasted 2 weeks unfortunetly and it is squeeling again. I dont no what to do about it, they say they wont change the actually disks as there fine and brand new everything now twice over. the noise wasnt there before, is constant when ever i turn right, is getting worse and pads have already been replaced. If anyone could help me on this, it would be grate,
marcward3301 is offline
Old 07-09-2005   #2
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: Squeeling brakes, urgent
Back plates rubbing? Easy check,just pull them out abit with a screwdriver.Doubt it though as surely they would of thought of this?
T14086 is offline
Old 07-09-2005   #3
hot hot tamale!
Hellcat's Avatar
Trader Rating: (3)
Hellcat has donated!
What anti-squeel system does the punto use? Springs or shims?
Hellcat is offline
Old 08-09-2005   #4
Trader Rating: (0)
Angry Re: Squeeling brakes, urgent
I havent got a clue what they have done to the car and i also havent got a clue what the punto brake system parts are. I ant got a clue when it comes to things like this. i really need help on this as its doing my head in.
Old 08-09-2005   #5
thefishdude's Avatar
Trader Rating: (0)
thefishdude has donated! United Kingdom
coper grease on the back of the pads stops squeeling. if they havent put any on maybe its that
2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm
thefishdude is offline
Old 09-09-2005   #6
Trader Rating: (0)
Thanks. DO i put the copper grease on the face that touchs the brake disk or on the part i can see when lookin straight ahead at it, as you can tell i havent got a clue about cars
Old 09-09-2005   #7
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Nooooo! On the outside of the pad (the bit that doesn't touch the disc),just put thin smear over back especially the (inner pad) bit that is pushed by the caliper piston.Also do the ends (hook shaped bits at end) as these slide in the caliper,its alsways worthwhile scraping the dust/crap of the part of the caliper that the pads slide back & foward on.
I cant believe the garage hasn't done this already,standard practice!
Bent back the backplate while your there,its the inner shield plate on the inner side of the disc at the bottom.
T14086 is offline
Old 10-09-2005   #8
Trader Rating: (0)
Unhappy Re: Squeeling brakes, urgent
Done that also now and it hasnt made a bit of difference. Could it be the pads, there just standard ones as far as i no. Should i buy some Fiat pads especially for the punto? Could that work? dunno what else to try. Thanks
Old 10-09-2005   #9
Banned
Trader Rating: (0)
if it only happens when you turn right, sounds like it could be a bearing or cv joint to me?
The Jim is offline
Old 11-09-2005   #10
Trader Rating: (0)
I've been told it defo isnt a wheel bearing. How would you check to see if its the cv joint? All my bush's on the front are worn and i have been told to replace them. Could this be a factor in it?
Old 15-09-2005   #11
Trader Rating: (0)
Talking Re: Squeeling brakes, urgent
hi
I had same problem with my punto new discs, pads etc. after this work was done car would squeal whenever i turned right, and when i,m 10 minutes into a journey. after researching this i discovered that by chamfering the pads( grinding the edge of the new pads) this would bed them in early, with my new found knowledge i went back to kwikfit and asked them if this had been done to the pads, they assured me this had been done. The manager took a look and ressured me that everthing was OK. One week later i took the car back to kwikfit and demanded that they chamfer the pads while i watched, realising that this customer wasn,t a pushover they duly obliged. Since the pads has been chamfered, NO MORE SQUEELING
colleen is offline
Old 15-09-2005   #12
Trader Rating: (0)
Thumbs up Re: Squeeling brakes, urgent
Finally, someone who can help me. So did they grind all the way round the pads to make them that little bit smaller or something? You really dont no how much that has help me. If u could tel me how much they grinded off etc i maybe able to do this myself. Thanks a lot
Old 15-09-2005   #13
Trader Rating: (0)
I think what it comes down to is.....Do not pay the chimps at quick fit to do anything, they are way over priced and never do a good job.
smelluel55sx is offline
Old 15-09-2005   #14
Forum Moderator
T14086's Avatar
Trader Rating: (0)
Rear brake shoes yeah but not front pads there should be no reason to do this unless,wrong pads,cheap pads,discs are knackered.
New pads shouldnt need this (a few hundred yards in 2nd gear with brakes on is enough to bed them in) it is routine to hammer off surface rust around edge of discs..did they do this?
T14086 is offline
Old 15-09-2005   #15
Trader Rating: (0)
Haven't got a clue what they have done to my pads. They say they have done everythin they can. Its got so bad now that when i brake everyone around me stares at my car. And since im fittin new alloys and a kit its the last thing i want. I just dunno wat to do anymore, buy whole new brake system? i dunno but its drivin me crazy
Bleeding the brakes. Trancendental Lets Talk FIAT 6 08-06-2005 22:05
(G) Brakes!!! choppertoo Stilo 10 03-06-2005 10:36
(T) squeeling brakes nickphonics18 Punto 6 24-04-2005 12:08
(T) brakes Diesel20 Stilo 11 11-05-2004 19:06
(G) AHHH my brakes dont work! Bushboy Uno 6 13-11-2003 23:58
