The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 31-08-2005   #1
phil_GT's Avatar
Trader Rating: (0)
Question boost guages
i could do with some help on this matter been told to pull the clocks out and t connect to the original pipe which will mean i cannot take my boost guage back off and i dont fancy pulling my clocks out as i have no idea what im doing.
could i t connect the vaccume pipe that is connected to the dump valve the thin blue pipe??????? then if i mess it up i can just buy that pipe and replace it agen
also if my boost guage is capable will it show vaccume as well?
phil_GT is offline
Old 31-08-2005   #2
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: boost guages
you should be able to find the connection in the engine bay for the standard dump valve in one of the vacuum pipes in the inlet manifold. on your boost gauge 0 is atmospheric pressure nd when its off boost it will sit at a - number showing the vacuum
custard is offline
Old 31-08-2005   #3
phil_GT's Avatar
Trader Rating: (0)
Re: boost guages
rite was brave enuf to see how the dials came out that was easy then the fun began lol
the pipe from the back of the clocks came off really easy compared to what people on here have said a slight tug came off
cut it in half to put the T connector on (i know i have to leave a dial on now tho)
went to put the shorter end of the vaccume pipe onto no problems.....
the other side wouldnt go on so i had 2 warm it up using a ciggerette lighter burning ma sen in the process got it on i was well im pressed so decided to put dials back in then i hit a problem
where do i put the pipe tried takin speaker out no hole tried to drill 1 cant get the angel in the end it in now running down the back of the clocks under the coin holder up the side of the dash driver side into the back of the guage
got to admit might not be tidy yet till i get some tube holders of some sort but... it sits at 20 vaccumme i think and when i boot it in 3/4 it goes upto about 20psi wasnt doing too much tho coz of insurance was meerly a drive to test it worked on a safe unlit lonely nat speed road
if required i will do a how to guide let me know what u think
the dial came with 3 wires i have only used 2 due to my no nowledge of fiat electrical the wires are connected as follows.... earth is to the stereo earth and on is to the remote wire which only runs when the ignition is on.
phil_GT is offline
Boost gauge andybtsn Lets Talk FIAT 0 24-05-2005 12:44
Blitz Dual SBC Type R Boost Controller Nad 20VT Auction Watch 0 30-01-2005 16:22
Turbo boost warning light (TD) GazC Tempra 1 29-12-2004 21:29
(T) boost probs stuuyh Punto 7 04-08-2004 09:12
Re-maps/ Chips/ Boost gauge kenny f Coupe 2 17-05-2004 20:18
