The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 29-08-2005   #1
Trader Rating: (0)
Crazy temperature gugue
I have just started having trouble with the temperature gague on my Mk2 Sporting Punto. Typically, I drive along for 5/10 mins and the temperature guage does not move from it's resting point. Then, it suddenly goes up to the normal position (where it has always been since new). All is well for a while and then it suddenly shoots up to the top and the red warning light comes on. It's then up and down like a yoyo for the rest of the journey. The temperature gague CAN'T be displaying the correct coolant temperature as the fluctuations could not occur that quickly. It doesn't go up in stationary traffic or when parked up.
There is now water leaking from the radiator, the water levels are fine, there is no 'mayo' round the filler cap. The heating inside the car works perfectly and the car runs fine and is not overheating.
Any ideas? Dodgy temperature sender??
coedkernew is offline
Old 29-08-2005   #2
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: Crazy temperature gugue
i would say check the connection on the sender 1st before replacing it. could just be loose/dirty
custard is offline
Old 29-08-2005   #3
Trader Rating: (0)
sounds a bit like a knackared voltage regualator in the instrument cluster, you really need to eliminate the sensor and wiring before you touch that tho.
-=[Punto sporting 1.2 16v]=-
-=[Ex-fiat tech]=-
kebab is offline
Old 30-08-2005   #4
Trader Rating: (0)
Thanks for the suggestions...
Sounds like a really divvy question, but where abouts is the temperature sender located so that I can check to see if it's dirty/loose?
T
Old 30-08-2005   #5
Trader Rating: (0)
Just been to FIAT Cwmbran. They have had a quick look and it appears that tthe thermostat may be sticking and I have air in the system. This would account for the wild fluctuations in temperature that the sensor is sending to the termperature gague. It would also explain the gurgling sound when revving the engine. Booked in to be fixed next week.
(T) Temperature Gauge issues arc Cinquecento / Seicento 35 29-07-2007 01:15
Temperature display Ravenna Multipla 3 06-01-2005 19:44
(G) UNO 1108 i.e. temperature sensors andre79ge Uno 2 18-10-2004 11:12
(G) Fiat Uno, Engine temperature problems pikkumies Uno 3 29-08-2003 20:34
(G) Missing handbook and engine temperature issues Lestat Cinquecento / Seicento 2 13-02-2003 22:58
