| I HAVE JUST BOUGHT SOME ALLOYS AND THE GUY IN MOTORWORLD RECKONS IF I PUT ALLOYS ON MY MK1 PUNTO I NEED TO USE WHAT HE CALLED "WOBBLY" BOLTS AND THEY COST AROUND £50! DOES ANY1 KNOW IF THIS IS CORRECT. THANX.
| Was VXR enough :( | Re: ALLOY WHEEL "WOBBLY" BOLTS Hi Yep he's correct. But you can get them from Here for less than half that price (You want the 4x98 ones)
__________________ Fiat Punto Active Skoda Fabia vRS Vauxhall Astra VXR SEAT Ibiza 20VT FR Renault Clio 182 & Honda CB600FA Hornet | ||
| | #3 | ||
| Re: ALLOY WHEEL "WOBBLY" BOLTS Ok Thanx For That But Is There Just One Kind Or Do They Come In Various Sizes/diameters Etc? Thanx
| | #4 | ||
| Was VXR enough :( | Re: ALLOY WHEEL "WOBBLY" BOLTS Actually yeah, ive read on here that some dont fit in the holes on the wheels. That wouldnt be a problem if you bought from motorworld, because im sure they'd get you the right ones. What wheels have you bought?
| | #5 | ||
| Re: ALLOY WHEEL "WOBBLY" BOLTS Jus Got Some 15" Bsa Cobra With Low Profile Tyres Off A Friend For Free???
| | #6 | ||
| Was VXR enough :( | Re: ALLOY WHEEL "WOBBLY" BOLTS Well the actual bolt threaded bit fits through the hole, but wobbly bolts have a loose collar around the top and this sometimes is too big to fit in the hole on the wheel. Id just get the ones from motorworld- if they dont fit you can easily take them back. You got the wheels free you should have 50quid to spend
| | #7 | ||
| Re: ALLOY WHEEL "WOBBLY" BOLTS No Probs Will Go Motorworld Jus 2 B Safe Cheers For The Info.
| | #8 | ||
| Re: ALLOY WHEEL "WOBBLY" BOLTS hgow do these work as i have a brand new set of tsw volcano's sitting on my clio i didnt really wanna sell and can u put locking nuts on with this type?
__________________ http://img.photobucket.com/albums/v6...83/Phil_GT.jpg | |||
| | #9 | ||
| Was VXR enough :( | Re: ALLOY WHEEL "WOBBLY" BOLTS Theyre just a normal bolt with a loose collar round the top that makes up for the 2mm difference in PCD. Fiats are 4x98 and aftermarket wheels are usually 4x100. You'll have some on your car now! Yes you can use locking bolts, but they need the loose collar aswell. If you do use wobbly bolts the spiggot ring that pushes up against the hub needs to be the right size/diameter.
| | #10 | ||
| Re: ALLOY WHEEL "WOBBLY" BOLTS Locking wobblys are very difficult to find, 3 wobbly bolts and 1 normal locking bolt per wheel is fine and is what most other people use.
| | #11 | ||
| Re: ALLOY WHEEL "WOBBLY" BOLTS k how much are 16" tsw worth then?
| | #12 | ||
| Re: ALLOY WHEEL "WOBBLY" BOLTS Depends on condition, etc. I notice that your B pillars are body coloured, yet on GTs they should be matt black...
| | #14 | ||
| Re: ALLOY WHEEL "WOBBLY" BOLTS Surely if you use 3 wobbly and one fixed wheel nut then the wheels wouldnt rotate right? Wouldnt that off centre the wheel?
__________________ 1242 16v 119bhp/115lbft GSR F10i, Supersprint Manifold/System, GSR Modified Map, Raised Compression, 3piece valve cut. www.clubfirepower.co.uk | |||
| | #15 | ||
| Re: ALLOY WHEEL "WOBBLY" BOLTS think ill stick to the ones that are with it then sav ethe hassle and theb pillar i have no idea how it was when i got it
| | black_fiatsei | Cinquecento / Seicento | 0 | 05-08-2005 19:31 |
| | mckcrich | Cinquecento / Seicento | 6 | 05-05-2005 18:57 |
| | Idge | Stilo | 9 | 22-04-2004 23:53 |
