| How to remove Custom fascia Hi, I've put the custom facia plastic piece in my punto so I can have a custom stereo in my car. Just wandering how to remove it as there doesn't seem to be anyway to get it off once it has been clipped in? Thanks
__________________ Punto Active 1.2/04 | |||
| Was VXR enough :( | Re: How to remove Custom fascia You can only pull it and probably break it, like I did to both the ones I had
__________________ Fiat Punto Active Skoda Fabia vRS Vauxhall Astra VXR SEAT Ibiza 20VT FR Renault Clio 182 & Honda CB600FA Hornet | ||
| | #3 | ||
| GP T-Jet Owner | Re: How to remove Custom fascia I never found a way of getting it out, broke one of the clips on mine! Why do you want to remove it if you dont mind me asking?
__________________ Sold: 02 (52) Sassi Grey Stilo 1.6 Active, Full Merkur Bodykit, MS Design Spoiler, 18" Lenso Shu Wheels, 50/40 Drop, Ragazzon Quad Exhaust Now: 07 (57) Crossover Black Grande Punto 1.4 Tjet 120 Sporting....Standard | ||
| | #4 | ||
| Re: How to remove Custom fascia Doesn't sound healthy, I want to know as I just may be selling my car soon, but probably won't do. Plus it's nice to know that you can get to the back of your stereo if need be ![]() I'm looking at a Focus Zetec but I don't know if I should do it.
| | #5 | ||
| Join Date: Oct 2003 Location: buxton the land that time forgot
Thanks: 1 Trader Rating: (0) | Re: How to remove Custom fascia yep will be virtually impossible to get out without break ing im affriad. you may be able to prse the clips down using flat blade. but chance of movingenough down so you can get it out are slim
__________________ 2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm | ||
| | #7 | ||
| Re: How to remove Custom fascia I managed to get mine off without breaking it. I just simple pulled very gently all around it until eventually one of the holding clips popped out and the rest followed easily. Bit of luck was involved but being patient may mean getting it off in one piece.
| | #8 | ||
| Burninator of threads! | Re: How to remove Custom fascia actually getting your aftermarket stereo out shouldn't be a prob, remove removable bit, then read instructions, the black surround should come off easily then you should be able to use two small screwdrivers to remove stereo. Then getting that facia bit out is pot luck. You could just smash it, or you could be gentle, but if new owner doesn't want it, what does it matter?
__________________ ![]() Volvo for Life | ||
| | #9 | ||
| Re: How to remove Custom fascia I've only recently (start of this month) replaced the cassette radio in mine with a JVC one together with the appropriate fascia plate... The fascia plate clips in nice and solidly, just like everyone else's does in this thread, by the actual JVC cd/radio/etc unit itself that I've got doesn't. It lines up pretty much flush with the fascia plate but that's it. Even with the front face of the JVC removed all I have to do is pull on the unit itself and it comes out very easily. Is this how it's supposed to be or have I installed the JVC CD/radio unit incorrectly?
__________________ | |||
| | #10 | ||
| Re: How to remove Custom fascia Sounds like you havent bent the holding spikes over (Stops it rattling in there)To get out : get a paint scraper. and stick it in and move it sideways (force is required) and it bends them all back in normal position (holding spikes) and slides out
| | #11 | ||
| Re: How to remove Custom fascia I have a JVC unit in mine. You haven't pulled down the spikes as mentioned previously! My fit is terrible - all bent - not enough room behing unit for the tonnes of wires. Looks **** too - not OEM enough for me. | |||
| | #12 | ||
| Re: How to remove Custom fascia You need a set of remover pins
| | #13 | ||
| Re: How to remove Custom fascia you dont need to remove the custom plate to access the back, just use clips down the side of the bare stereo n bobs ur unc!
| | Donn | Punto | 11 | 29-05-2008 12:03 |
| | 1986Uno45S | Uno | 3 | 03-08-2005 00:07 |
| Exhausts... Custom Vs Off-Shelf | GhostWKD | Polling Station | 22 | 27-05-2005 00:12 |
| | is_it_me | Cinquecento / Seicento | 5 | 17-06-2004 17:52 |
| | J.R Racing | Cinquecento / Seicento | 4 | 13-03-2004 02:33 |
