| Hi Got a problem since replacing my Punto's Headgaskit Whenever i want to start the car, i have to unplug the sockets from the Block BOX and then re-connect them in order for the car to start, but lately even that doesnt work anymore, sometimes it works fine and when it does switch on, the orange COde symbol stays on the dash board and sometimes it dissapears as it should do. One other trick i have learned in order to start the car is to put it into first gear and then switch on the ignition and after a few jumps it wud start. I only have one blue kay for the car and my dealer says that i need to rplace the whole lock system to solve the problem which wud cost around £750. Any help and advise wud be grately appreciated. thanx
| __________ | Re: Fiat Punto 55 start up problem welcome to the forum ![]() I only have one blue kay for the car and my dealer says that i need to rplace the whole lock system to solve the problem which wud cost around £750. that bits bolloks, what you unpluging from where? if it starts after it been jumping about in first sounds like loose conection somewhere
__________________ Binki | ||
| | #3 | |||||
| | #4 | ||
| this is where i stand | Re: Fiat Punto 55 start up problem or buy an ecu with a non soldered eeprom, and bung a chip in there. don't quote me on this, but i think one of mckrichs chips should work fine in a punto55. I tested a cinq novitec chip in a punto60 and that worked fine
__________________ | ||
| | #5 | ||
| Re: Fiat Punto 55 start up problem Hi inayat, I just happen to have a "codefree" Punto-ecu that you are looking for. You can email me at: info@schepers-autotechniek.com Best regards, Johan Schepers www.schepers-autotechniek.com
| | bazoooka | Punto | 0 | 23-06-2005 21:02 |
| | FIAT_PUNTO_1.7TD | Punto | 1 | 12-06-2005 19:50 |
| Fiat Punto N reg - won't start | puntoprincess | Other Fiats | 1 | 30-07-2004 10:07 |
| Fiat recalls - Punto [1] | roby76it | Lets Talk FIAT | 0 | 14-04-2003 02:50 |
