| Air bag light I Have A Mk2 Punto Sporting With A Small Problem. Whenever I Instantly Hit The Brakes The Airbag Light Flickers On For About A Second. I Have Been Advised That It Sounds Like A Poor Earth Connection. If So How Do I Try And Find The Poor Earth And Sort It?
| Re: Air bag light this sounds like an auto electricians job.take my advice and get somebody in.plenty of good one out there who are mobile.
| | #3 | ||
| Re: Air bag light My Sporting had this exact same problem and the dealer replaced the instrument panel then the body computer but it turned out that it was actually the ignition switch that was faulty and causing the airbag light to come on when dabbing the brakes. After the instrument panel was replaced all sorts of other problem developed like random warning lights coming on even when the engine was switched off. After the body computer was replaced the engine kept cutting out or wouldn't start or would start even when the code warning was on. After the ignition switch was replaced everything back to normal Good job it was all under warranty as they just seemed to be working on trial and error
| | #4 | ||
| Re: Air bag light So would you say its the ignition switch?
| | #5 | ||
| Re: Air bag light
| | #6 | ||
| Re: Air bag light OK. It has been into a Fiat dealer and the problem did stop for about a week. It seems to only flicker now and again when I hit the brakes suddenly. Is the ignition switch somehow connected to the air bag then? I suppose the air bag must have a live feed through the ignition switch when it is on maybe.
| | #7 | ||
| Forum Moderator | Re: Air bag light Needs a ignition switch.
| | #8 | ||
| Re: Air bag light Thanks alot. It was at Fiat dealer for the day. I dont think they did anything to be honest. Just remembered it got warrantee on it till may next year so it will be going back. The third year, which is a dealer warrantee, does that still cover everything I wonder. The car will be three in May next year.
| air bag warning light | pat polin | Lets Talk FIAT | 13 | 20-04-2005 23:50 |
| | Silvasportin23 | Punto | 2 | 30-12-2004 16:12 |
| | chrisunoman | Uno | 13 | 23-12-2004 01:15 |
| | bobsinger | Marea | 5 | 02-05-2004 02:44 |
| | wongy008 | Punto | 6 | 21-01-2004 04:56 |
