| Punto 1.7 D - engine won't stop ?? Strange one this.. I can remove the ignition key on my Punto 1.7 d and the engine keeps going.. All I need to do is touch the throttle and the engine stops ?? Any ideas... must be something to do with the cut off valve i think ? Punto 1.7D
| Re: Punto 1.7 D - engine won't stop ?? I hope that the problem may be with the fuel cut off switch in the diesel pump..... If possible tell me the brand of the Diesel pump so that i can explain the place of the fuel cut off switch.... Regards, Jeyakar.T
| | #3 | ||
| Re: Punto 1.7 D - engine won't stop ?? bit of an old post this one
__________________ 1998 PHASE 2 PEUGEOT 306 IN BLAZE YELLOW | |||
| | #5 | ||
| Re: Punto 1.7 D - engine won't stop ?? if it has, his neighbours will be going mad
| | #7 | ||
| It stopped ! The neigbours moved out anyway.. It ended up being the cut off valve on the fuel pump. Sorry i took so long to answer .. only 2 and bit years though
__________________ Steve A Punto 1.7D Last edited by euro; 25-10-2007 at 14:56. | |||
| | #9 | ||
__________________ Steve A Punto 1.7D | |||
| | shotter | Punto | 17 | 30-12-2006 12:45 |
| | sneaky_alien | Punto | 18 | 06-08-2004 19:00 |
| | Scorg | Punto | 4 | 14-08-2003 04:43 |
| | thetman | Stilo | 6 | 12-07-2003 00:30 |
