The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 09-08-2005   #1
steviepab's Avatar
Trader Rating: (1)
mk2 angel eyes instructions and contact.
This link contains full instructions with fitting.
http://www.1llusion.nl/Angel/PicSite...g/puntoMk2.htm
(click english flag)
They can be purchesed on the dutch ebay. They are almost on every day.
Just type http://www.ebay.nl
And search for punto Angel eyes
Saved me a lot.
mk2 punto in white, I think i need help!!
http://img.photobucket.com/albums/v2...SIGNITURE2.jpg
steviepab is offline
Old 09-08-2005   #2
steviepab's Avatar
Trader Rating: (1)
Re: mk2 angle eyes instructions and contact.
Oh forgot to mention a few things. First of all when cutting lights make sure you do it in a large space and wear goggles and the dremmel does more melting than cutting. Second where he has heat resistand silicone, after looking for 3 weeks for it i found one from halfords called loctite 595 adhesive sealant as it is heat proof just doesn't mention it apart from a little caption at the bottom. Use that for the bulbs and use normal silicone to put the cover back on as that is ok up to 140.c so it is fine for that. Make sure you mesure the bulbs up before you take off the silver covers as the bulbs are the size off the outer ring and don't fit in the middle. as i first thought. Lol. Good job i managed to get it off before it started setting. Also to take off the silver cover around the main light you have to take the indicator cover first which is cliped on by 3 clips at the back. Disconnect the bottom one and you will find the other two will just pop off. (with a little help). If i remember anything else i will add it to this thread.
Old 09-08-2005   #3
Trader Rating: (0)
Netherlands
About the silicone heat resistand kit.
You need to use a glue or kit that stays highly flexible after drying and is heat resistant.
Your headlight is made off different materials and these different materials all have ther own ways to deal with heat.
Iff you use a kit that does not stay flexible, the different enlargement due to heat off the different materials will make the rings crack.
By using kit or glue thats stays flexible after drying you won't get these problems.
1llusion is offline
Old 13-08-2005   #4
Banned
Trader Rating: (0)
they seem really expensive to me on fatladz, any particular reason?
how are they switched, can they be wired into your sidelights without major problems?
The Jim is offline
Old 14-08-2005   #5
steviepab's Avatar
Trader Rating: (1)
Proberbly because he is the only stockist that is baised in the uk.
You can wire them to your side lights if you want or to a seperate switch. I have mine wired to the side lights. It comes with 4 bulbs and two conector boxes, which has the basic two wires (ground and live)
Excuse the sp its been a long day.
Old 06-02-2007   #6
Trader Rating: (0)
Re: mk2 angel eyes instructions and contact.
theres a groupbuy for those at my club.. those mk2 angelseyes were made by a member of our club
Tr!bal is offline
Old 06-02-2007   #7
steviepab's Avatar
Trader Rating: (1)
They looked fantastic. Very easy to do. Shame i had to sell her. Oh well someone down south will be showing them off. Am thinking of selling my clio to get another punto so i might get another set.
Old 16-04-2007   #8
Trader Rating: (0)
Guys, whats the difference between side repeater and indicators? and also, Does anyone know how to remove the orange plastic inside the headlamps of a punto mk2 A?
samsonite is offline
Old 16-04-2007   #9
missey's Avatar
Trader Rating: (0)
missey has donated! United Kingdom
Side repeaters are the small lights at the rear of your wings, at the side of the car...indicators are the ones in your headlights/rears.
I don't have a mk2, but im sure it must be possible, try a search, but you would need to replace with orange bulbs
1.2 16v Sporting & 1.2 16v ELX
missey is offline
Old 16-04-2007   #10
Trader Rating: (0)
ohhhh i thought the ones of the side of the car were called indicators too
Old 16-04-2007   #11
steviepab's Avatar
Trader Rating: (1)
When the lights are apart the plastic indicator cover clips off. The hardest part is cutting your lights apart. Looks fantastic when it is done tho. See my pics on my post about the angle lights.
Old 17-04-2007   #12
Trader Rating: (0)
did you cut them open? because i read in this forum somewhere that you can leave them in an oven on low temperature for a couple of minutes to melt the glue... sounds better then cutting them open to me!
Old 17-04-2007   #13
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
thats a mk1, mk2 lights wont even fit in a standard oven
Binki
dave is offline
Old 17-04-2007   #14
Trader Rating: (0)
No way am i going to cut up my headlights! maybe if i had to get some from a scrappy, but not until i do! I dont understand, my headlights have clips on them... dont the clips do anything?
Old 17-04-2007   #15
__________
dave's Avatar
Trader Rating: (10)
are you sure you got a mk2?
ive cut mine, only problem i had was getting burnt by hot plastic coming off dremmel wheel
Binki
dave is offline
