ophthalmofox
- Sep 12, 2014
- 38
- 11
hello everybody
my dashboard backlight went off . I checked the fuse box and found that the fuse of right ( passenger side ) headlight is blown I changed it and the dashboard light came on again so I discovered that it have the same wiring with the right headlight .
after a while it blew again . I changed it with a higher amp fuse but smoke arise so I removed it instantly .
my question is can I make the light of the dashboard irrelevant from the headlight ? I want to bypass this problem all I need is the backlight
thank you so much
thank you so much
