Re: Please help.....update
Hi All, just to say my car passed the MOT now, all issues resolved.
Just to summarise the issues in case it helps others:
i) The small holes in the rear right wheel arch: were not structural, so no MOT fail. (I will have to look at getting them patched up so the water doesnt get in that area though).
ii) Handbrake: biting point was very high, easily adjusted from within the inside of the car and tightened quite straightforward once you take off the plastic cover, it was just a case of tightening a bolt to a particular level.
iii) Rear light columns, indicator causing the other lights to flicker in time too:
- this was caused by water having got into the unit, causing some rust at the lowest bulb, causing a shorting effect.
- however this didnt resolve the problem fully, we realised that the metal points which you plug into the connecting (white) plug, had some tiny oxidisation on them too. So with a file and some sandpaper, scored them to clean them back to fresh/raw metal, and once plugged in all resolved and fixed.
Thank you all for your help. The car is doing very well. I'm on 98450 miles..... should reach 100,000 in the year.
p.s. not many around in my area now (probably due the rust getting to the older ones), so it's like driving a more unique car. :slayer:
