i didnt have a hyanes.
anyway.. as now i have found out what each wire does, i am going to post it here for any future reference.
the 8F ECU wiring colours for the P75 1.2 MPI engine:
a big thick RED wire, is a constant live from the battery.
ORANGE wire, its an ignition live.
BROWN with WHITE stripe is the fuel pump
BLUE wire, it is for the REV counter
LIGHT GREY with GREEN stripe goes to the CODE box (ECU pin 7)(wire colours match on ECU and CODE box connector!)
BLUE with GREEN stripe goes to the injector/engine management light (ECU pin 6)
LIGHT GREY with YELLOW stripe goes to the oil light
LIGHT GREY with BLACK stripe goes to the battery/Alternator light
LIGHT GREY only wire goes to the temperature gauge
I hope this helps some one in the future!
i also have found out that if you give the CODE light a permanent live, with the engine and ignition OFF, it flashes like an alarm "armed" light. looks cool, but i would swap the bulb out for an LED. as it is a bit more power saving and the constant on/off on a filament/incandescent bulb causes them to blow faster whereas it does not effect an LED.
