Technical Anti Roll bar bush
chesh
Established member
I've bought a set of bushes from Strongflex, have done the outer ones and the wishbone ones.
When I got to do the inner ones, I found out on the left side, that one of the bracket's bolt is welded to the chassis:
What would you suggest me to do? is there anyway to fix and fit a bolt to it?
Maybe go to exhaust shop that can do welding or it's not the same metal?
I guess the bolt was cranked, I bought the car like that so I don't know who fixed it.
One way of the bracket:
Other side:
Don't think I can replace the bush like that
You don't actually need the anti-roll bar...
With the Punto being a front wheel drive vehicle and front heavy anyway, you would gain a handling advantage by removing the front anti-roll bar which may result in less understeer (Unless the chassis differs between the different spec models significantly, which I don't think it does).
The down side is that the car body will roll more so your comfort may be reduced.
Alternatively; as all ready suggested, you could cut it off and bolt it back on or even re-weld it in a different location. I.e. cut the bracket elsewhere.
Before you ask; I am an Automotive & Motorsport Engineer and I am not making this up :eek:
He's not making it up. But it's a crude solution (certainly people have run Centos without front ARBs in an attempt to reduce understeer). Most folk doing more high speed motorsport put an ARB (or a fatter ARB) on the back to acheive a more graduated/graduatable response.
But the inner ARB bushes don't seem to wear that much -- although they don't exactly like MIG welders in close proximity either -- you can probably get away with it as is for the foreseeable future.
One more question
On my 75SX I fitted 19mm inner bushes.
When I ordered for my 1.6 cabrio I got 18mm bushes.
Both seem to fit.
I know the ARB is actually 19mm. Would that be critical?
Well although it doesn't look too nice, finally got to change that bush.
I got it re-weld. so all the front now wears Strongflex bushes :)
