eurotrash12
- Nov 26, 2013
- 8
- 3
turns over but will not fire up. i tried jumping the battery seems to turn over better but just doest have enough it seems to fire up engine completely. what could this be?
Yes, you should be able to hear if your year is trained. When you turn the ignition on before you fire you can here the pump being primed.how would i be able to tell if the fuel pump is working can you hear it? also i have a 1.1 L engine does it have a fuel relay switch or just a pressure switch on the pump itself
