dumbledore
Member
- Jul 4, 2010
- 745
- 144
6 months ago changed the clutch and reported here that the gearbox is showing some problems. Initially I suspected it was the input shaft bearing but now subsequently don't think this is the case.
I need a final verdict. Last week the noise started to get louder. The noise appears to disappear above 50-60mph but this is just related to the noise getting uniform the higher the speed.
It appears the noise is related to the speed of the car and not the gear. So the pitch gets higher and more uniform the higher the speed. The noise happens when both accelerating and decelerating. If I go down a hill and take the car off the gear or press the clutch then noise goes away.
So my suspicion now is that the fault must be in the final drive, the diff or the input shaft CV joints.
As most of the failure I am getting with this car are common Mk1 failure, my question to you lot is is this common failure of mk1 gearbox fault?
