- Jan 20, 2013
- 6,151
- 1,228
interesting, how much smaller final drive are we talking about here
just came back from highway with my mk1, top speed a little above 160km/h and above 170 going downhill 155/70 13 and 145/70 13 tires, so smaller the tire higher the top speed on stock stuff?
Smaller the tyre the more (tyre) revolutions to cover a given distance, so higher indicated top speed.
Yes, I see what you mean. I was lucky. The replacement box came with one CV joint fitted and cup. I was hoping to use it and then fitted the other cup to the box. After fitting the box I realised the cup and CV joint on the new box was not suitable and I could not use. So I need to get it out and replaced it with my old one. So I guess I was lucky. My worry at the moment is that the drive shaft seals as they have been disturbed by the cups removal may start leaking!!!If anyone doing it reads this post, the trick is to replace the cups one at a time (I'm assuming that's what you did) or the diff will tend to drop (can be fished back into place with a broom handle!).
Good outcome, though.
