can anyone tell me what turbo will fit on a 1.4 gt turbo some one said the md103 is there any other one that are compatible as im building a spare engine and would like to upgrade from the standard one or if you have a spare one lying about
when you say fit.... do you mean direct bolt on replacement for stock manifold?
As if you are going to upgrade i would highly recommend tubular manifold and that basically means you can fit whatever you like too. The stock manifold is not the best design and also they crack - really really common that they crack, which is even more likely with a bigger turbo making even more heat...
