| Wheel / brake squeal ? Its either my front drivers side or rear passenger side that intermitantly makes a squealing / noise. I say its intermitant as some days it doesn't do it - some days it does. When it does do it it stops when I steer left ( eg on the motorway) or I brake! Could it be brake dust between the pad and disk OR is it something more sinister? Its starting to annoy me and I can't keep driving round with the Music drowning it out! HELP! PLEASE!
__________________ Punto HGT. 2000 (W) SILVER. . No Longer a FIAT owner. Punto Sold - Can't say i would bother with a FIAT again - or go to Italy on Holiday | |||
| | #2 | |||
One of the other options is a wheel bearing may be failing (haven't had this happen to me so I don't know what wheel bearing squeal sounds like) which would be bad news as it helps keep the wheel attached to driveshaft, hopefully other members will be able to point out the warning signs of this.
__________________ FIAT is a way of life not a 4 door box. (Note: anything I say is my opinion and may be missing some of the facts, so don't take it as the absolute truth.) | ||||
| | #3 | ||
| Re: Wheel / brake squeal ? Hi I'd like to know if you've found the fault - my punto active sport 1.2 3 door 52 reg does exactly the same. Passenger side front wheel screeches on longer journeys and stops when brakes applied or I turn to the left slightly. Taken it to 1 garage already - couldn't find anything wrong.
| | #4 | ||
| Re: Wheel / brake squeal ? my 2001 mk2 has started doing the same, i think mines on the right as it makes the noise when i turn left I have recently checked the pads on that wheel so im thinking it might be because i have disturbed the wheel some how
| | #5 | ||
| Re: Wheel / brake squeal ? Mine did it on long journeys; I just got used to tapping the brakes from time to time
__________________ Big Northern Monkey No longer a Fiat owner: Audi A2 1.4TDI SE in silver with climate and rear bench seat. A beautiful car. smart city-coupe Mk6 pure in Jack black with grey scordic trim. No mods (even the rubbish standard stereo) | |||
| | J333EVO | Cinquecento / Seicento | 36 | 25-02-2006 01:57 |
| | picklez | Cinquecento / Seicento | 4 | 03-03-2005 17:17 |
| | cruisestoke | Cinquecento / Seicento | 2 | 01-10-2004 13:31 |
| Wheel Changing | Stu DemonD | Ulysse | 11 | 13-07-2004 02:35 |
