| Ignition coil signal Does anybody know what is the voltage of the signal the ecu send on the Punto mk2 8v coils? (the LT side, those thin wires). Is it a gnd signal (0v), 5v or 12v? Thanks
__________________ --- Punto mk2 8v--- *Int & Ext neons**Tinting**Int Alum trim**Momo gear set**Momo pedal set* *Body graphics**Custom Ice install**Custom A'Pex Integration CAI**Sports exhaust**Racing Seat Belts**Removed seats**Lexan Windows**Weight reduction* | |||
| Re: Ignition coil signal
| | #3 | ||
| Re: Ignition coil signal No, no misfiring (Thanks God), I am trying to install the Greddy Emanage and everything is working except the ignition cause I do not know the signal. So the ecu sends a 0v signal? ie, grounds the coil that needs to be fired right?
| | #4 | ||
| Re: Ignition coil signal Yes you have a 12v supply to both coils and then they are switched by the ecu to earth to collapse the magnetic fields and fire.
| | #5 | ||
| Re: Ignition coil signal Thanks alot, I will try it as soon as everything arrives. Btw, without switching on the car do you know which one of the wires is the static 12v and which is the 0v ecu signal pls? Thanks again.
| | braden | Stilo | 5 | 29-03-2005 13:14 |
| | rosswald | Punto | 1 | 20-01-2005 12:29 |
| | coolhand_mike | Uno | 0 | 06-10-2004 23:58 |
| | quater | Punto | 2 | 10-05-2004 21:59 |
| | br4duk | Uno | 3 | 04-01-2004 23:24 |
